Datasheet ATtiny13, ATtiny13V - Summary (Microchip) - 7
Manufacturer | Microchip |
Description | 8-bit AVR Microcontroller with 1K Bytes In-System Programmable Flash |
Pages / Page | 22 / 7 — ATtiny13. 4. Register Summary. Address. Name. Bit 7. Bit 6. Bit 5. Bit 4. … |
Revision | Rev. 08-01-2010 |
File Format / Size | PDF / 574 Kb |
ATtiny13. 4. Register Summary. Address. Name. Bit 7. Bit 6. Bit 5. Bit 4. Bit 3. Bit 2. Bit 1. Bit 0. Page
ATtiny13 4. Register Summary Address Name Bit 7 Bit 6 Bit 5 Bit 4 Bit 3 Bit 2 Bit 1 Bit 0 Page
0x3F SREG I T H S V N Z C page 9 0x3E Reserved – – – – – – – – 0x3D SPL SP[7:0] page 11 0x3C Reserved – 0x3B GIMSK – INT0 PCIE – – – – – page 46 0x3A GIFR – INTF0 PCIF – – – – – page 47 0x39 TIMSK0 – – – – OCIE0B OCIE0A TOIE0 – page 74 0x38 TIFR0 – – – – OCF0B OCF0A TOV0 – page 75 0x37 SPMCSR – – – CTPB RFLB PGWRT PGERS SELFPR- page 97 0x36 OCR0A Timer/Counter – Output Compare Register A page 74 0x35 MCUCR – PUD SE SM1 SM0 – ISC01 ISC00 page 32 0x34 MCUSR – – – – WDRF BORF EXTRF PORF page 41 0x33 TCCR0B FOC0A FOC0B – – WGM02 CS02 CS01 CS00 page 72 0x32 TCNT0 Timer/Counter (8-bit) page 73 0x31 OSCCAL Oscillator Calibration Register page 27 0x30 Reserved – 0x2F TCCR0A COM0A1 COM0A0 COM0B1 COM0B0 – – WGM01 WGM00 page 69 0x2E DWDR DWDR[7:0] page 96 0x2D Reserved – 0x2C Reserved – 0x2B Reserved – 0x2A Reserved – 0x29 OCR0B Timer/Counter – Output Compare Register B page 74 0x28 GTCCR TSM – – – – – – PSR10 page 77 0x27 Reserved – 0x26 CLKPR CLKPCE – – – CLKPS3 CLKPS2 CLKPS1 CLKPS0 page 28 0x25 Reserved – 0x24 Reserved – 0x23 Reserved – 0x22 Reserved – 0x21 WDTCR WDTIF WDTIE WDP3 WDCE WDE WDP2 WDP1 WDP0 page 41 0x20 Reserved – 0x1F Reserved – 0x1E EEARL – – EEPROM Address Register page 20 0x1D EEDR EEPROM Data Register page 20 0x1C EECR – – EEPM1 EEPM0 EERIE EEMPE EEPE EERE page 21 0x1B Reserved – 0x1A Reserved – 0x19 Reserved – 0x18 PORTB – – PORTB5 PORTB4 PORTB3 PORTB2 PORTB1 PORTB0 page 56 0x17 DDRB – – DDB5 DDB4 DDB3 DDB2 DDB1 DDB0 page 56 0x16 PINB – – PINB5 PINB4 PINB3 PINB2 PINB1 PINB0 page 57 0x15 PCMSK – – PCINT5 PCINT4 PCINT3 PCINT2 PCINT1 PCINT0 page 47 0x14 DIDR0 – – ADC0D ADC2D ADC3D ADC1D AIN1D AIN0D page 80, page 94 0x13 Reserved – 0x12 Reserved – 0x11 Reserved – 0x10 Reserved – 0x0F Reserved – 0x0E Reserved – 0x0D Reserved – 0x0C Reserved – 0x0B Reserved – 0x0A Reserved – 0x09 Reserved – 0x08 ACSR ACD ACBG ACO ACI ACIE – ACIS1 ACIS0 page 79 0x07 ADMUX – REFS0 ADLAR – – – MUX1 MUX0 page 91 0x06 ADCSRA ADEN ADSC ADATE ADIF ADIE ADPS2 ADPS1 ADPS0 page 92 0x05 ADCH ADC Data Register High Byte page 93 0x04 ADCL ADC Data Register Low Byte page 93 0x03 ADCSRB – ACME – – – ADTS2 ADTS1 ADTS0 page 94 0x02 Reserved – 0x01 Reserved – 0x00 Reserved –
7
2535JS–AVR–08/10 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port B (PB5:PB0) 1.1.4 RESET 2. Overview 2.1 Block Diagram 3. General Information 3.1 Resources 3.2 Code Examples 3.3 Data Retention 4. Register Summary 5. Instruction Set Summary 6. Ordering Information 7. Packaging Information 7.1 8P3 7.2 8S2 7.3 S8S1 7.4 20M1 7.5 10M1 8. Errata 8.1 ATtiny13 Rev. D 8.2 ATtiny13 Rev. C 8.3 ATtiny13 Rev. B 8.3.1 Wrong values read after Erase Only operation 8.3.2 High Voltage Serial Programming Flash, EEPROM, Fuse and Lock Bits may fail 8.3.3 Device may lock for further programming 8.3.4 debugWIRE communication not blocked by lock-bits 8.3.5 Watchdog Timer Interrupt disabled 8.3.6 EEPROM can not be written below 1.9 Volt 8.4 ATtiny13 Rev. A 9. Datasheet Revision History 9.1 Rev. 2535J-08/10 9.2 Rev. 2535I-05/08 9.3 Rev. 2535H-10/07 9.4 Rev. 2535G-01/07 9.5 Rev. 2535F-04/06 9.6 Rev. 2535E-10/04 9.7 Rev. 2535D-04/04 9.8 Rev. 2535C-02/04 9.9 Rev. 2535B-01/04 9.10 Rev. 2535A-06/03
