Datasheet LT6105 (Analog Devices)
DescriptionPrecision, Extended Input Range Current Sense Amplifier
Pages / Page20 / 1 — FEATURES. DESCRIPTION. Very Wide, Over-the-Top®, Input Common Mode Range. …
File Format / SizePDF / 384 Kb
FEATURES. DESCRIPTION. Very Wide, Over-the-Top®, Input Common Mode Range. - Extends 44V Above V– (Independent of V+)
Datasheet LT6105 Analog Devices
LT6105 Precision, Extended Input Range Current Sense Amplifi er
FEATURES DESCRIPTION
n
The LT®6105 is a micropower, precision current sense
amplifi er with a very wide input common mode range.
- Extends –0.3V Below V–
The LT6105 monitors unidirectional current via the volt- n
Wide Power Supply Range: 2.85V to 36V
age across an external sense resistor. The input common n
Input Offset Voltage: 300μV Maximum
mode range extends from –0.3V to 44V, with respect to n
Gain Accuracy: 1% Max
the negative supply voltage (V–). This allows the LT6105 n Gain Confi gurable with External Resistors to operate as a high side current sense monitor or a low n Operating Current: 150μA side current sense monitor. It also allows the LT6105 to n Slew Rate: 2V/μs monitor current on a negative supply voltage, as well as n Sense Input Current When Powered Down: 1nA continuously monitor a battery from full charge to depletion. n Full-Scale Output Current: 1mA Minimum The inputs of LT6105 can withstand differential voltages n Operating Temperature Range –40°C to 125°C up to ±44V, which makes it ideal for monitoring a fuse or n Available in 2mm × 3mm DFN and 8-Lead MSOP MOSFET switch. Packages Gain is confi gured with external resistors from 1V/V to 100V/V. The input common mode rejection and power
supply rejection are in excess of 100dB and the input offset voltage is less than 300μV. A typical slew rate of 2V/μs n High Side or Low Side Current Sensing ensures fast response to unexpected current changes. n Current Monitoring on Positive or Negative Supply The LT6105 can operate from an independent power Voltages n supply of 2.85V to 36V and draws only 150μA. When Battery Monitoring n V+ is powered down, the sense pins are biased off. This Fuse/MOSFET Monitoring n prevents loading of the monitored circuit, irrespective of Automotive n the sense voltage. The LT6105 is available in a 6-lead DFN Power Management n and 8-lead MSOP package. Portable Test/Measurement Systems , LT, LTC, LTM and Over-the-Top are registered trademarks of Linear Technology Corporation. All other trademarks are the property of their respective owners.
TYPICAL APPLICATION Gain Error vs Input Voltage
4
Gain of 50 Current Sense Amplifi er
V+ = 12V 3 VSENSE = 50mV R SOURCE IN = 100Ω LT6105 A –0.3V TO 44V 2 V = 50V RIN2 T V + A = – 40°C S 100Ω +IN 1 + T V A = 25°C OUT 0 0.02Ω RIN1 VOUT = 1V/A 100Ω –IN – –1 R GAIN ERROR (%) OUT T T A = 125°C A = 85°C V – 4.99k S –2 V+ V– –3 TO LOAD 2.85V TO 36V 6105 TA01 –4 R R V = V ( + − V OUT − • ; A OUT = ; R 0 5 10 15 20 25 30 35 40 45 1 = R ) OUT S S V IN IN2 = RIN R R IN IN V + S INPUT VOLTAGE (V) 6105 TA01b 6105fa 1
