Datasheet LTC6431-15 (Analog Devices) - 2
Description50Ω Gain Block IF Amplifier
Pages / Page16 / 2 — absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion …
File Format / SizePDF / 645 Kb
absoluTe MaxiMuM raTings. pin conFiguraTion. (Note 1). orDer inForMaTion LEAD FREE FINISH. TAPE AND REEL. PART MARKING*
absoluTe MaxiMuM raTings pin conFiguraTion (Note 1) orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING*
LTC6431-15
Total Supply Voltage (VCC to GND)...5.5V TOP VIEW Amplifier Output Current (OUT) ...105mA IN GND V CC DNC DNC DNC RF Input Power, Continuous, 50Ω (Note 2)..15dBm 24 23 22 21 20 19 RF Input Power, 100µs Pulse, 50Ω (Note 2) ..20dBm DNC 1 18 OUT Operating Case Temperature DNC 2 17 GND Range (TCASE) ..–40°C to 85°C DNC 3 25 16 T_DIODE Storage Temperature Range .. –65°C to 150°C DNC 4 GND 15 DNC Junction Temperature (T DNC 5 14 DNC J) .. 150°C DNC 6 13 DNC 7 8 9 10 11 12 DNC GND V CC DNC DNC DNC UF PACKAGE 24-LEAD (4mm × 4mm) PLASTIC QFN TJMAX = 150°C, θJC = 54°C/W EXPOSED PAD (PIN 25) IS GND, MUST BE SOLDERED TO PCB
orDer inForMaTion LEAD FREE FINISH TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6431AIUF-15#PBF LTC6431AIUF-15#TRPBF 43115 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C LTC6431BIUF-15#PBF LTC6431BIUF-15#TRPBF 43115 24-Lead (4mm × 4mm) Plastic QFN –40°C to 85°C Consult LTC Marketing for parts specified with wider operating temperature ranges. *The temperature grade is identified by a label on the shipping container. Consult LTC Marketing for information on nonstandard lead based finish parts. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/
Dc elecTrical characTerisTics The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω. Typical measured DC electrical performance using Test Circuit A. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VS Operating Supply Range 4.75 5.0 5.25 V IS,TOT Total Supply Current All VCC Pins Plus OUT 75 85.1 100 mA l 67 112 mA IS,OUT Total Supply Current to OUT Pin Current to OUT 62 71 92 mA l 55 95 mA ICC,OUT Current to VCC Pin Either VCC Pin May Be Used 12 14 16 mA l 12.5 16.5 mA 643115f 2 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts
