Datasheet LTC6431-15 (Analog Devices) - 4
Description50Ω Gain Block IF Amplifier
Pages / Page16 / 4 — ac elecTrical characTerisTics. TA = 25°C (Note 3), VCC = 5V, ZSOURCE = …
File Format / SizePDF / 645 Kb
ac elecTrical characTerisTics. TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise
ac elecTrical characTerisTics TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise
LTC6431-15
ac elecTrical characTerisTics TA = 25°C (Note 3), VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise noted. Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS Frequency = 300MHz
S21 Power Gain De-Embedded to Package 15.5 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 46.5 dBm B-Grade 45.5 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –89.0 dBc B-Grade –87.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –60.0 dBc HD3 Third Harmonic Distortion POUT = 6dBm –86.0 dBc P1dB Output 1dB Compression Point 20.6 dBm NF Noise Figure De-Embedded to Package 3.41 dB
Frequency = 380MHz
S21 Power Gain De-Embedded to Package 15.4 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 46.0 dBm B-Grade 45.0 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –88.0 dBc B-Grade –86.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –57.0 dBc HD3 Third Harmonic Distortion POUT = 6dBm –87.0 dBc P1dB Output 1dB Compression Point 20.6 dBm NF Noise Figure De-Embedded to Package 3.48 dB
Frequency = 500MHz
S21 Power Gain De-Embedded to Package 15.3 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 44.5 dBm B-Grade 43.5 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –85.0 dBc B-Grade –83.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –55.6 dBc HD3 Third Harmonic Distortion POUT = 6dBm –77.0 dBc P1dB Output 1dB Compression Point 20.6 dBm NF Noise Figure De-Embedded to Package 3.60 dB
Frequency = 600MHz
S21 Power Gain De-Embedded to Package 15.3 dB OIP3 Output Third-Order Intercept Point POUT = 2dBm/Tone, Δf = 1MHz A-Grade 41.5 dBm B-Grade 40.5 dBm IM3 Third-Order Intermodulation POUT = 2dBm/Tone, Δf = 1MHz A-Grade –79.0 dBc B-Grade –77.0 dBc HD2 Second Harmonic Distortion POUT = 6dBm –53.6 dBc HD3 Third Harmonic Distortion POUT = 6dBm –69.0 dBc P1dB Output 1dB Compression Point 20.6 dBm NF Noise Figure De-Embedded to Package 3.67 dB 643115f 4 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts
