Datasheet LTC6433-15 (Analog Devices) - 6
DescriptionLow Frequency to 1.4GHz 50Ω Gain Block IF Amplifier
Pages / Page16 / 6 — Typical perForMance characTerisTics. TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD …
Typical perForMance characTerisTics. TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless
LTC6433-15
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise noted. S parameter measurements are performed using 1µF feedback capacitor. K Factor vs Frequency Over Noise Figure vs Frequency S Parameters vs Frequency Temperature Over Temperature
20 10 16 TCASE = 100°C TCASE = 100°C 9 TCASE = 85°C 14 TCASE = 85°C 10 S11 TCASE = 50°C TCASE = 25°C S21 8 TCASE = 25°C T 12 CASE = 0°C S12 7 T T 0 CASE = 0°C CASE = –20°C S22 TCASE = –20°C T 6 10 CASE = –40°C TCASE = –40°C –10 5 8 4 6 MAGNITUDE (dB) –20 ACTOR (UNITLESS) 3 NOISE FIGURE (dB) K F 4 2 –30 1 2 –40 0 0 0.1 1 10 100 1000 5000 0.1 1 10 100 1000 5000 .01 0.1 1 10 100 1000 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 643315 G01 643315 G02 643315 G03
S11 vs Frequency Over Temperature S21 vs Frequency Over Temperature
0 20 TCASE = 100°C TCASE = 85°C 18 –5 TCASE = 50°C 16 TCASE = 25°C TCASE = 0°C 14 –10 TCASE = –20°C T 12 CASE = –40°C –15 10 8 TCASE = 100°C MAGNITUDE (dB) –20 T MAGNITUDE (dB) CASE = 85°C 6 TCASE = 50°C TCASE = 25°C 4 –25 TCASE = 0°C 2 TCASE = –20°C T –30 CASE = –40°C 0 0.1 1 10 100 1000 5000 0.1 1 10 100 1000 5000 FREQUENCY (MHz) FREQUENCY (MHz) 643315 G04 643315 G05
S12 vs Frequency Over Temperature S22 vs Frequency Over Temperature
0 0 TCASE = 100°C TCASE = 100°C TCASE = 85°C –5 TCASE = 85°C –5 TCASE = 50°C TCASE = 50°C –10 TCASE = 25°C TCASE = 25°C T –15 T –10 CASE = 0°C CASE = 0°C TCASE = –20°C TCASE = –20°C T –20 CASE = –40°C TCASE = –40°C –15 –25 –30 MAGNITUDE (dB) –20 MAGNITUDE (dB) –35 –40 –25 –45 –30 –50 0.1 1 10 100 1000 5000 0.1 1 10 100 1000 5000 FREQUENCY (MHz) FREQUENCY (MHz) 643315 G06 643315 G07 643315f 6 For more information www.linear.com/LTC6433-15 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information DC Electrical Characteristics Pin Configuration AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation S Parameters Package Description Typical Application Related Parts
