Datasheet LTC6433-15 (Analog Devices) - 8
Description | Low Frequency to 1.4GHz 50Ω Gain Block IF Amplifier |
Pages / Page | 16 / 8 — Typical perForMance characTerisTics. TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD … |
File Format / Size | PDF / 1.3 Mb |
Typical perForMance characTerisTics. TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless
LTC6433-15
Typical perForMance characTerisTics TA = 25°C, VCC = 5V, ZSOURCE = ZLOAD = 50Ω, unless otherwise noted. Measurements are performed using Test Circuit A, measuring from 50Ω SMA to 50Ω SMA without de-embedding (Note 4). 2nd Harmonic vs Frequency Over 3rd Harmonic vs Frequency Over 4th Harmonic vs Frequency Over RF Power Out RF Power Out RF Power Out
–40 –40 –40 VCC = 5V, T = 25°C VCC = 5V, T = 25°C VCC = 5V, T = 25°C ZIN = ZOUT = 50Ω –45 –45 ZIN = ZOUT = 50Ω –45 ZIN = ZOUT = 50Ω RF P –50 OUT = 6dBm RF P –50 OUT = 6dBm –50 RF POUT = 8dBm RF POUT = 8dBm –55 RF POUT = 10dBm –55 RF POUT = 10dBm –55 –60 –60 –60 –65 –65 –65 –70 –70 2ND HARMONIC (dBc) –75 –75 –70 3RD HARMONIC (dBc) 4TH HARMONIC (dBc) RF P –80 –80 OUT = 6dBm –75 RF POUT = 8dBm –85 –85 RF POUT = 10dBm –80 –90 –90 0.1 1 10 100 1000 0.1 1 10 100 1000 0.1 1 10 100 1000 FREQUENCY (MHz) FREQUENCY (MHz) FREQUENCY (MHz) 643315 G13 643315 G14 643315 G15
ITOTAL vs VCC ITOTAL vs TCASE ITOTAL vs Input Power
100 110 100 TCASE = 25°C VCC = 5V 95 105 95 90 100 90 85 95 80 90 85 75 (mA) AL (mA) 85 AL (mA) 80 AL I TOT 70 I TOT 80 I TOT 75 65 75 70 60 70 55 65 65 VCC = 5V, T = 25°C ZIN = ZOUT = 50Ω 50 60 60 4 4.25 4.50 4.75 5 5.25 5.50 5.75 6 –40 –20 0 20 40 60 80 100 –15 –10 –5 0 5 10 15 VCC (Volts) TCASE (C) RF POWERIN (dBm) 643315 G16 643315 G17 643315 G18
RF Power Out vs RF Power In Gain vs RF Power In Over Frequency Over Frequency P1dB vs Frequency
22 16 21.0 VCC = 5V, T = 25°C VCC = 5V, T = 25°C T = 25°C 20 ZIN = ZOUT = 50Ω ZIN = ZOUT = 50Ω 15 20.5 ZIN = ZOUT = 50Ω 18 20.0 14 16 19.5 14 13 19.0 (dBm) 12 12 18.5 OUT 10 GAIN (dB) RF P 8 11 18.0 P1dB (dBm) FREQ = 100kHz FREQ = 100kHz 6 FREQ = 1MHz FREQ = 1MHz 17.5 10 FREQ = 10MHz FREQ = 10MHz 17.0 4 FREQ = 100MHz FREQ = 100MHz V 9 CC = 4.5V 2 FREQ = 400MHz FREQ = 400MHz 16.5 VCC = 5.0V FREQ = 1GHz FREQ = 1GHz V 0 8 CC = 5.5V 16.0 –15 –12 –9 –6 –3 0 3 6 9 12 15 –15 –12 –9 –6 –3 0 3 6 9 12 15 0.1 1 10 100 1000 RF POWERIN (dBm) RF POWERIN (dBm) FREQUENCY (MHz) 643315 G19 643315 G20 643315 G21 643315f 8 For more information www.linear.com/LTC6433-15 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information DC Electrical Characteristics AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation Applications Information S Parameters Package Description Related Parts Features Applications Typical Application Description Absolute Maximum Ratings Order Information DC Electrical Characteristics Pin Configuration AC Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuit A Operation S Parameters Package Description Typical Application Related Parts
