Datasheet LT1116 (Analog Devices) - 2
Description12ns, Single Supply Ground-Sensing Comparator
Pages / Page10 / 2 — absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion …
File Format / SizePDF / 185 Kb
absoluTe MaxiMuM raTings. (Note 1). pin conFiguraTion. orDer inForMaTion TUBE. TAPE AND REEL. PART MARKING*. PACKAGE DESCRIPTION
absoluTe MaxiMuM raTings (Note 1) pin conFiguraTion orDer inForMaTion TUBE TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION
LT1116
Supply Voltage (V+) to GND ..7V Latch Pin Voltage ...Equal to Supplies Negative Supply Voltage (V–) ... –7V to GND Output Current (Continuous) ...±20mA Voltage Operating Temperature Range ... 0°C to 70°C Differential Input Voltage .. ±15V Storage Temperature Range ..–65°C to 150°C Inputs Voltage (Either Input) ...(V–) –0.3V to 15V Lead Temperature (Soldering, 10 sec) ...300°C
pin conFiguraTion
TOP VIEW TOP VIEW V+ 1 8 Q OUT V+ 1 8 Q OUT +IN 2 7 Q OUT + +IN 2 7 Q OUT + –IN 3 – 6 GND –IN 3 – 6 GND V– 4 5 LATCH V– 4 5 LATCH ENABLE ENABLE N8 PACKAGE S8 PACKAGE 8-LEAD PDIP 8-LEAD PLASTIC SO TJMAX = 100°C, θJA = 130°C/W TJMAX = 100°C, θJA = 160°C/W
orDer inForMaTion TUBE TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LT1116CN8#PBF NA 1116 8-Lead PDIP 0°C to 70°C LT1116CS8#PBF LT1116CS8#TRPBF 1116 8-Lead Plastic SO 0°C to 70°C Consult LTC Marketing for parts specified with wider operating temperature ranges.*The temperature grade is identified by a label on the shipping container. Parts ending with PBF are RoHS and WEEE compliant. For more information on tape and reel specifications, go to: http://www.linear.com/tapeandreel/. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix. 1116fc 2 For more information www.linear.com/LT1116
