Datasheet LT1116 (Analog Devices) - 5
Description12ns, Single Supply Ground-Sensing Comparator
Pages / Page10 / 5 — Typical perForMance characTerisTics. Output Low Voltage (VOL). Supply …
File Format / SizePDF / 185 Kb
Typical perForMance characTerisTics. Output Low Voltage (VOL). Supply Current vs Temperature. Positive Supply Current
Typical perForMance characTerisTics Output Low Voltage (VOL) Supply Current vs Temperature Positive Supply Current
LT1116
0.8 35 60 VS = ±5V, VIN = 30mV V– = 0 0.7 30 POSITIVE SUPPLY CURRENT 50 0.6 25 40 0.5 TJ = –55°C 20 0.4 T 30 J = 25°C 15 VOLTAGE (V) 0.3 CURRENT (mA) CURRENT (mA) 20 10 T 0.2 TJ = 125°C J = 25°C NEGATIVE SUPPLY CURRENT TJ = 125°C 10 0.1 5 TJ = –55°C 0 0 0 0 2 4 6 8 10 12 14 16 18 20 –60 –40 –20 0 20 40 60 80 100 120 140 0 2 4 6 8 OUTPUT SINK CURRENT (mA) JUNCTION TEMPERATURE (°C) POSITIVE SUPPLY VOLTAGE (V) LT1116 • TPC10 LT1116 • TPC11 LT1116 • TPC12
Positive Supply Current Input Bias Current Positive Common Mode Limit
50 10 5 TJ = 25°C VS = ±5V 45 V T S = ±5V J = 125°C 40 T 0 4 J = 25°C 35 30 T –10 3 J = –55°C 25 20 –20 2 CURRENT (mA) 15 10 INPUT BIAS CURRENT (µA) –30 COMMON MODE VOLTAGE (V) 1 5 0 –40 0 1 10 100 –6 –4 –2 0 2 4 –60 –40 –20 0 20 40 60 80 100 120 140 SWITCHING FREQUENCY (MHz) INPUT VOLTAGE (V) JUNCTION TEMPERATURE (°C) LT1116 • TPC13 LT1116 • TPC14 LT1116 • TPC15
Negative Common Mode Limit Latch Pin Threshold Latch Pin Current*
0 2.6 300 V V S = ±5V S = 5V, OV –1 2.2 250 –2 1.8 OUTPUT LATCHED 200 –3 1.4 150 VOLTAGE (V) –4 1.0 CURRENT (µA) OUTPUT UNAFFECTED 100 COMMON MODE VOLTAGE (V) –5 0.6 50 V *CURRENT COMES OUT OF LATCH PIN S = ±5V BELOW THRESHOLD –6 0.2 0 –60 –40 –20 0 20 40 60 80 100 120 140 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 JUNCTION TEMPERATURE (°C) JUNCTION TEMPERATURE (°C) JUNCTION TEMPERATURE (°C) LT1116 • TPC16 LT1116 • TPC17 LT1116 • TPC18 1116fc For more information www.linear.com/LT1116 5
