Datasheet LT1715 (Analog Devices) - 3
Description4ns, 150MHz Dual Comparator with Independent Input/Output Supplies
Pages / Page20 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 255 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT1715
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. VCC = 5V, VEE = –5V, +VS = 5V, VCM = 1V, COUT = 10pF, VOVERDRIVE = 20mV, unless otherwise specifi ed. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VOS Input Offset Voltage (Note 6) 0.4 2.5 mV LT1715C, LT1715I l 3.5 mV LT1715H l 4 mV VHYST Input Hysteresis Voltage (Note 6) LT1715C, LT1715I l 2 3.5 6 mV LT1715H l 2 7 mV VOS/ΔT Input Offset Voltage Drift l 10 μV/°C IB Input Bias Current LT1715C, LT1715I l –6 –2.5 0 μA LT1715H l –7 0 μA IOS Input Offset Current LT1715C, LT1715I l 0.2 0.6 μA LT1715H l 1 μA CMRR Common Mode Rejection Ratio (Note 7) LT1715C, LT1715I l 60 70 dB LT1715H l 55 dB PSRR Power Supply Rejection Ratio (Note 8) l 65 80 dB AV Voltage Gain (Note 9) ∞ V + OH Output High Voltage ISOURCE = 4mA, VIN = VTRIP + 20mV l +VS – 0.4 V V – OL Output Low Voltage ISINK = 10mA, VIN = VTRIP – 20mV l 0.4 V fMAX Maximum Toggle Frequency (Note 10) 150 MHz tPD20 Propagation Delay VOVERDRIVE = 20mV (Note 11), 2.8 4 6 ns VCC = 5V, VEE = –5V LT1715C, LT1715I l 2.8 7 ns LT1715H l 2.8 8 ns VOVERDRIVE = 20mV, VCC = 5V, VEE = 0V 4.4 ns VOVERDRIVE = 20mV, VCC = 3V, VEE = 0V 3 4.8 6.5 ns LT1715C, LT1715I l 3 7.5 ns LT1715H l 3 8 ns tPD5 Propagation Delay VOVERDRIVE = 5mV, VEE = 0V (Notes 11, 12) 6 9 ns l 12 ns t + – SKEW Propagation Delay Skew (Note 13) Between tPD /tPD , VEE = 0V l 0.5 1.5 ns ΔtPD Differential Propagation Delay (Note 14) Between Channels l 0.3 1 ns tr Output Rise Time 10% to 90% 2 ns tf Output Fall Time 90% to 10% 2 ns t + JITTER Output Timing Jitter VIN = 1.2VP-P (6dBm), ZIN = 50 tPD 15 psRMS f = 20MHz (Note 15) t – PD 11 psRMS ICC Positive Input Stage Supply Current +VS = VCC = 5V, VEE = –5V LT1715C, LT1715I l 1 2 mA (per Comparator) LT1715H l 2.2 mA +VS = VCC = 3V, VEE = 0V LT1715C, LT1715I l 0.9 1.6 mA LT1715H l 1.8 mA IEE Negative Input Stage Supply Current +VS = VCC = 5V, VEE = –5V LT1715C, LT1715I l –4.8 –2.9 mA (per Comparator) LT1715H l –5.3 mA +VS = VCC = 3V, VEE = 0V LT1715C, LT1715I l –3.8 –2.4 mA LT1715H l –4.3 mA IS Positive Output Stage Supply Current +VS = VCC = 5V, VEE = –5V LT1715C, LT1715I l 4.6 7.5 mA (per Comparator) LT1715H l 8 mA VS = VCC = 3V, VEE = 0V LT1715C, LT1715I l 3.7 6 mA LT1715H l 6.5 mA 1715fa 3
