Datasheet LT1719 (Analog Devices) - 6
Description4.5ns Single/Dual Supply 3V/5V Comparator with Rail-to-Rail Output
Pages / Page22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. Output Low Voltage. Output High …
File Format / SizePDF / 220 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Output Low Voltage. Output High Voltage. vs Load Current. Supply Current vs Frequency
TYPICAL PERFORMANCE CHARACTERISTICS Output Low Voltage Output High Voltage vs Load Current Supply Current vs Frequency
LT1719
TYPICAL PERFORMANCE CHARACTERISTICS Output Low Voltage Output High Voltage vs Load Current vs Load Current Supply Current vs Frequency
0.5 0.0 9 +V +V 25°C S OR V+ = 5V S OR V+= 5V V V +V IN = –10mV (V) S 125°C IN = 10mV 8 S = 5V 125°C –0.2 0.4 125°C 7 VCC = 2.7V –55°C CLOAD = 20pF –0.4 25°C 6 25°C 0.3 –55°C 5 –0.6 CLOAD = 10pF OUTPUT VOLTAGE (V) SUPPLY CURRENT (mA) 4 S 0.2 –0.8 +V NO LOAD 25°C 3 OUTPUT VOLTAGE RELATIVE TO +V VCC = 2.7V 0.1 –1.0 2 0 4 8 12 16 20 0 4 8 12 16 20 0 10 20 30 40 OUTPUT SINK CURRENT (mA) OUTPUT SOURCE CURRENT (mA) FREQUENCY (MHz) 1719 G10 1719 G11 1719 G12
Shutdown Currents Shutdown Currents vs Shutdown Voltage vs Shutdown Voltage
4 5 IS 3 4 LT1719S6 LT1719S8 + 3 2 SUPPLY SUPPLY I 2 CURRENTS (mA) 1 CURRENT (mA) ICC 1 0 TA = 25°C V 0 EE = GND +V –50 S = VCC = 5V T –50 A = 25°C V+ = 5V SHDN PIN CURRENT (μA) SHDN PIN –100 CURRENT (μA) V –100 S –4 VS –3 VS –2 VS –1 VS V+ –4 V+ –3 V+ –2 V+ –1 V+ SHDN PIN VOLTAGE (V) SHDN PIN VOLTAGE (V) 1719 G13a 1719 G13b
Shutdown Currents Wake-Up Delay vs Temperature vs Temperature
700 SHUTDOWN = +VS – 0.5V +I 10 S 600 SHUTDOWN 500 PIN CURRENT 1 400 +IS 300 WAKE-UP DELAY (ns) SHUTDOWN CURRENTS (μA) SHUTDOWN PIN OPEN 0.1 200 VCC = +VS = 5V VEE = –5V 100 –50 –25 0 25 50 75 100 125 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) 1719 G14 1719 G15 1719fa 6
