Datasheet LTC6702 (Analog Devices) - 4
DescriptionTiny Micropower, Low Voltage Dual Comparators
Pages / Page12 / 4 — TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current. Input Leakage …
File Format / SizePDF / 369 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Supply Current. Input Leakage Current. vs Supply Voltage. vs Temperature. vs Input Voltage
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current Input Leakage Current vs Supply Voltage vs Temperature vs Input Voltage
LTC6702
TYPICAL PERFORMANCE CHARACTERISTICS Supply Current Supply Current Input Leakage Current vs Supply Voltage vs Temperature vs Input Voltage
50 35 5 V+ = 3V V+ = 3V 30 4 TOR (μA) 40 TOR (μA) V+ = 5V 125°C ARA ARA 25 V+ = 1.7V 3 30 125°C 20 25°C 2 –55°C 15 20 1 10 –55°C 85°C Y CURRENT PER COMP 10 Y CURRENT PER COMP 5 INPUT LEAKAGE CURRENT (nA) 0 SUPPL SUPPL 25°C 0 0 –1 0 1 2 3 4 5 6 –50 –25 0 25 50 75 100 125 –1 0 1 2 3 4 5 6 SUPPLY VOLTAGE (V) TEMPERATURE (°C) INPUT VOLTAGE (V) 6702 G01 6702 G02 6702 G03
Input Offset Current Maximum Toggle Rate vs Input Voltage Supply Current vs Toggle Rate vs Temperature
100 450 4 V+ = 3V 125°C VSTEP = 200mV VSTEP = 200mV 90 85°C 400 OVERDRIVE = 100mV OVERDRIVE = 100mV 25°C T C 80 A = 25°C LOAD = 10pF –55°C 350 NO CLOAD 70 V+ = 5V V+ = 3V 300 60 250 V+ = 3V 50 3 V+ = 5V 200 V+ = 1.7V 40 150 30 100 INPUT OFFSET CURRENT (pA) 20 MAXIMUM TOGGLE RATE (MHz) 10 50 V+ = 1.7V SUPPLY CURRENT PER COMPARATOR (μA) 0 0 2 –1 0 1 2 3 4 5 6 10k 100k 1M 10M –50 –25 0 25 50 75 100 125 INPUT VOLTAGE (V) TOGGLE RATE (Hz) TEMPERATURE (°C) 6702 G04 6702 G05 6702 G06
Input Offset Voltage Input Common Mode Limits vs Supply Voltage Hysteresis vs Supply Voltage vs Temperature
5 8 V+ 4 7 V+ –0.5 3 25°C 6 2 125°C 125°C V+ –1.0 5 1 25°C 0 –55°C 4 V+ –1.5 –1 –55°C 3 HYSTERESIS (mV) GND –2 2 INPUT OFFSET VOLTAGE (mV) –3 –0.5 1 INPUT COMMON MODE LIMITS (V) –4 –5 0 –1.0 1 2 3 4 5 6 1 2 3 4 5 6 –50 –25 0 25 50 75 100 125 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) TEMPERATURE (°C) 6702 G07 6702 G08 6702 G09 6702fa 4
