Datasheet LMC7101 (Microchip) - 2
ManufacturerMicrochip
DescriptionLMC7101 is a 500kHz gain bandwidth amplifier designed to operate from 2.7V to 12V single-ended power supplies with guaranteed performance at supply voltages of 2.7V, 3V, 5V, and 12V
Pages / Page12 / 2 — Absolute Maximum Ratings (Note 1). Operating Ratings (Note 1). Note 2. …
File Format / SizePDF / 132 Kb
Absolute Maximum Ratings (Note 1). Operating Ratings (Note 1). Note 2. Note 3. Note 4. Note 5. Electrical Characteristics (2.7V)
Absolute Maximum Ratings (Note 1) Operating Ratings (Note 1) Note 2 Note 3 Note 4 Note 5 Electrical Characteristics (2.7V)
LMC7101 Micrel, Inc.
Supply Voltage (V – V ) ... 15V Supply Voltage (V – V ) .. 2.7V to 12V V+ V– V+ V– Differential Input Voltage (V – V ) ... – V ) Ambient Temperature (T ) ... –40 IN+ IN– ±(VV+ V– A °C to +85°C I/O Pin Voltage (V , V ),
Note 2
Junction Temperature (T ) ... –40 IN OUT J °C to +125°C ... V + 0.3V to V – 0.3V V+ V– Max. Junction Temperature (T ),
Note 3
... +125 J(max) °C Junction Temperature (T ) .. +150 J °C Package Thermal Resistance (θ ),
Note 4
.. 325 JA °C/W Storage Temperature ... –65°C to +150°C Max. Power Dissipation ..
Note 3
Lead Temperature (soldering, 10 sec.) ... 260°C ESD,
Note 5
.. 2kV
V+ = +2.7V, V– = 0V, V = V = V+/2; R = 1M = 25 CM OUT L Ω; TJ °C,
bold
values indicate –40°C ≤ TJ ≤ +85°C; unless noted
LMC7101A LMC7101B Symbol Parameter Condition Typ Min Max Min Max Units
V Input Offset Voltage 0.11 6 9 mV OS TCV Input Offset Voltage Average Drift 1.0 OS µV/°C I Input Bias Current 1.0
64 64
pA B I Input Offset Current 0.5
32 32
pA OS R Input Resistance >1 T IN Ω CMRR Common-Mode Rejection Ratio 0V ≤ V CM ≤ 2.7V,
Note 6
70 50 50 dB V Input Common-Mode Voltage input low, CMRR CM ≥ 50dB –0.3 0.0 0.0 V input high, CMRR ≥ 50dB 3.0 2.7 2.7 V PSRR Power Supply Rejection Ratio V+ = 1.35V to 1.65V, V– = 60 50 45 dB –1.35V to –1.65V, V = 0 CM C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, R = 10k 2.699 2.64 2.64 V O L output low, R = 10k 0.001 0.06 0.06 V L output high, R = 2k 2.692 2.6 2.6 V L output low, R = 2k 0.008 0.1 0.1 V L I Supply Current V = V+/2 0.5 0.81 0.81 mA S OUT
0.95 0.95
mA SR Slew Rate 0.4 V/µs GBW Gain-Bandwidth Product 0.5 MHz
Electrical Characteristics (3.0V)
V+ = +3.0V, V– = 0V, V = V = V+/2; R = 1M = 25 CM OUT L Ω; TJ °C,
bold
V Input Offset Voltage 0.11 4 7 mV OS
6 9
mV TCV Input Offset Voltage Average Drift 1.0 OS µV/°C I Input Bias Current 1.0
64 64
32 32
pA OS R Input Resistance >1 T IN Ω LMC7101 2 February 2005
