Datasheet MIC7300 (Microchip) - 2
ManufacturerMicrochip
DescriptionThe MIC7300 is a high-performance CMOS operational amplifier featuring rail-to-rail input and output with strong output drive capability
Pages / Page12 / 2 — Absolute Maximum Ratings (Note 1). Operating Ratings (Note 2). Note 3. …
File Format / SizePDF / 68 Kb
Absolute Maximum Ratings (Note 1). Operating Ratings (Note 2). Note 3. Note 5. Note 4. Note 6. DC Electrical Characteristics (2.2V)
Absolute Maximum Ratings (Note 1) Operating Ratings (Note 2) Note 3 Note 5 Note 4 Note 6 DC Electrical Characteristics (2.2V)
MIC7300 Micrel
Supply Voltage (V – V ) ... 12V Supply Voltage (V – V ) .. 2.2V to 10V V+ V– V+ V– Differential Input Voltage (V – V ) ... ±12V Junction Temperature (T ) ... –40°C to +85°C IN+ IN– J I/O Pin Voltage (V , V ),
Note 3
Package Thermal Resistance,
Note 5
IN OUT ... V + 0.3V to V – 0.3V SOT-23-5 (θ ) .. 260°C/W V+ V– JA Junction Temperature (T ) .. +150°C MSOP-8 (θ ) .. 85°C/W J JA Storage Temperature ... –65°C to +150°C Max. Power Dissipation ..
Note 4
Lead Temperature (soldering, 10 sec.) ... 260°C ESD,
V = +2.2V, V = 0V, V = V = V /2; R = 1MΩ; T = 25°C,
bold
values indicate –40°C ≤ T ≤ +85°C;
Note 7
; unless noted V+ V– CM OUT V+ L J J
Symbol Parameter Condition Min Typ Max Units
V Input Offset Voltage 1.0 9 mV OS TCV Input Offset Voltage Average Drift 1.0 µV/°C OS I Input Bias Current 0.5 pA B I Input Offset Current 0.25 pA OS R Input Resistance >1 TΩ IN CMRR Common-Mode Rejection Ratio 0V ≤ V ≤ 2.2V,
Note 9
45 65 dB CM V Input Common-Mode Voltage input low, CMRR ≥ 45dB –0.3 0.0 V CM input high, CMRR ≥ 45dB 2.2 2.5 V ±PSRR Power Supply Rejection Ratio V = V  = 1.1V to 2.5V, V = 0 55 75 dB V+ V– CM C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, R = 100k, 0.15 1 mV O L specified as V – V
1
mV V+ OUT output low, R = 100k 0.15 1 mV L
1
mV output high, R = 2k 10 33 mV L specified as V – V
50
mV V+ OUT output low, R = 2k 10 33 mV L
50
mV output high, R = 600Ω 33 110 mV L specified as V – V
165
mV V+ OUT output low, R = 600Ω 33 110 mV L
165
mV I Output Short Circuit Current sinking or sourcing,
Note 8
20 40 mA SC I Supply Current V = V+/2 0.7 2.0 mA S OUT
AC Electrical Characteristics (2.2V)
V = 2.2V, V = 0V, V = V = V /2; R = 1MΩ; T = 25°C,
bold
Note 7
SR Slew Rate 0.5 V/µs GBW Gain-Bandwidth Product 0.55 MHz φ Phase Margin C = 0pF 80 ° m L C = 2500pF 40 ° L G Gain Margin 10 dB m MIC7300 2 June 2005
