Datasheet MIC7122 (Microchip) - 2
ManufacturerMicrochip
DescriptionThe MIC7122 is a dual high-performance CMOS operational amplifier featuring rail-to-rail inputs and outputs
Pages / Page8 / 2 — Absolute Maximum Ratings (Note 1). Operating Ratings (Note 2). Note 3. …
File Format / SizePDF / 52 Kb
Absolute Maximum Ratings (Note 1). Operating Ratings (Note 2). Note 3. Note 4. Note 5. Note 6. DC Electrical Characteristics (2.2V)
Absolute Maximum Ratings (Note 1) Operating Ratings (Note 2) Note 3 Note 4 Note 5 Note 6 DC Electrical Characteristics (2.2V)
MIC7122 Micrel
Supply Voltage (V – V ) .. 16.5V Supply Voltage (V – V ) .. 2.2V to 15V V+ V– V+ V– Differential Input Voltage (V – V ) ... ±10V Junction Temperature (T ) ... –40°C to +85°C IN+ IN– J I/O Pin Voltage (V , V ),
Note 3
Max. Power Dissipation ..
Note 4
IN OUT ... V + 0.3V to V – 0.3V V+ V– Package Thermal Resistance,
Note 5
Junction Temperature (T ) .. +150°C MSOP-8 (θ ) .. 200°C/W J JA Storage Temperature ... –65°C to +150°C Lead Temperature (soldering, 10 sec.) ... 260°C ESD,
Note 6
.. 1000V
V = +2.2V, V = 0V, V = V = V /2; R = 1MΩ; T = 25°C,
bold
values indicate –40°C ≤ T ≤ +85°C;
Note 7
; unless noted V+ V– CM OUT V+ L J J
Symbol Parameter Condition Min Typ Max Units
V Input Offset Voltage 0.5 9 mV OS TCV Input Offset Voltage Average Drift 3.0 µV/°C OS I Input Bias Current 1.0 10 pA B
64 500
pA I Input Offset Current 0.5 5 pA OS
32 250
pA R Input Resistance >1 TΩ IN CMRR Common-Mode Rejection Ratio -0.3V ≤ V ≤ 2.5V,
Note 9
45 65 dB CM ±PSRR Power Supply Rejection Ratio V = V  = 1.1V to 2.5V, V = V = 0 60 85 dB V+ V– OUT CM C Common-Mode Input Capacitance 3 pF IN V Output Swing output high, R = 100k, 0.15 1 mV O L specified as V – V
1
mV V+ OUT output low, R = 100k 0.15 1 mV L
1
mV output high, R = 2k 8 33 mV L specified as V – V
50
mV V+ OUT output low, R = 2k 8 33 mV L
50
mV output high, R = 600Ω 26 110 mV L specified as V – V
165
mV V+ OUT output low, R = 600Ω 26 110 mV L
165
mV I Output Short Circuit Current sinking or sourcing,
Note 8
20 50 mA SC I Supply Current both amplifiers 0.7 1.6 mA S
AC Electrical Characteristics (2.2V)
V = 2.2V, V = 0V, V = V = V /2; R = 1MΩ; T = 25°C,
bold
Note 7
SR Slew Rate 0.7 V/µs GBW Gain-Bandwidth Product 750 kHz φ Phase Margin C = 0pF 80 ° m L C = 200pF 40 ° L G Gain Margin 10 dB m Interamplifier Isolation
Note 12
90 dB MIC7122 2 June 2005
