Datasheet MCP6L01, MCP6L01R, MCP6L01U, MCP6L012, MCP6L014 (Microchip)
ManufacturerMicrochip
DescriptionThe MCP6L01 is a single general purpose op amp offering rail-to-rail input and output over the 1.8 to 6V operating range
Pages / Page38 / 1 — MCP6L01/1R/1U/2/4. 1 MHz, 85 µA Op Amps. Features:. Description:. Typical …
MCP6L01/1R/1U/2/4. 1 MHz, 85 µA Op Amps. Features:. Description:. Typical Applications:. Package Types. MCP6L01. MCP6L02. Design Aids:
Datasheet MCP6L01, MCP6L01R, MCP6L01U, MCP6L012, MCP6L014 Microchip
MCP6L01/1R/1U/2/4 1 MHz, 85 µA Op Amps Features: Description:
• Available in SC-70-5 and SOT-23-5 Packages The Microchip Technology Inc. MCP6L01/1R/1U/2/4 • Gain Bandwidth Product: 1 MHz (typical) family of operational amplifiers (op amps) supports • Rail-to-Rail Input/Output general purpose applications. The combination of rail- to-rail input and output, low quiescent current and • Supply Voltage: 1.8V to 6.0V bandwidth fit into many applications. • Supply Current: IQ = 85 µA/Amplifier (typical) This family has a 1 MHz Gain Bandwidth Product • Extended Temperature Range: -40°C to +125°C (GBWP) and a low 85 µA per amplifier quiescent • Available in Single, Dual and Quad Packages current. These op amps operate on supply voltages between 1.8V and 6.0V, with rail-to-rail input and output
swing. They are available in the extended temperature range. • Portable Equipment • Photodiode Amplifier
Package Types
• Analog Filters • Notebooks and PDAs
MCP6L01 MCP6L02
• Battery-Powered Systems SC-70-5, SOT-23-5 SOIC, MSOP V 1 5 V OUT DD V 1 8 V OUTA DD
Design Aids:
VSS 2 V V INA– 2 7 OUTB • SPICE Macro Model VIN+ 3 4 VIN– VINA+ 3 6 VINB– • FilterLab® Software VSS 4 5 VINB+ • Microchip Advanced Part Selector (MAPS)
MCP6L01R MCP6L04
• Analog Demonstration and Evaluation Boards SOT-23-5 • Application Notes SOIC, TSSOP V 1 5 V OUT SS V V 2 OUTA 1 14 VOUTD DD
Typical Application
V V 3 4 V INA– 2 13 VIND– IN+ IN– V 3 12 V R INA+ IND+ 1 R2 V
MCP6L01U
V V DD 4 11 SS IN VOUT V SOT-23-5 INB+ 5 10 VINC+ R3 V V 1 5 V INB– 6 9 VINC– V IN+ DD REF
MCP6L01
V V OUTB 7 8 VOUTC SS 2 VIN– 3 4 VOUT
Inverting Amplifier
 2009-2011 Microchip Technology Inc. DS22140B-page 1 Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Specifications TABLE 1-1: DC Electrical Specifications TABLE 1-2: AC Electrical Specifications TABLE 1-3: Temperature Specifications 1.3 Test Circuit FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 1.8V. FIGURE 2-2: Input Offset Voltage vs. Common Mode Input Voltage at VDD = 5.5V. FIGURE 2-3: Input Offset Voltage vs. Output Voltage. FIGURE 2-4: Input Common Mode Range Voltage vs. Ambient Temperature. FIGURE 2-5: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-6: CMRR, PSRR vs. Frequency. FIGURE 2-7: Measured Input Current vs. Input Voltage (below VSS). FIGURE 2-8: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Frequency. FIGURE 2-10: The MCP6L01/1R/1U/2/4 Show No Phase Reversal. FIGURE 2-11: Quiescent Current vs. Power Supply Voltage. FIGURE 2-12: Output Short Circuit Current vs. Power Supply Voltage. FIGURE 2-13: Ratio of Output Voltage Headroom to Output Current vs. Output Current. FIGURE 2-14: Small Signal, Noninverting Pulse Response. FIGURE 2-15: Large Signal, Noninverting Pulse Response. FIGURE 2-16: Slew Rate vs. Ambient Temperature. FIGURE 2-17: Output Voltage Swing vs. Frequency. 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Rail-to-Rail Inputs FIGURE 4-1: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-2: Output Resistor, RISO stabilizes large capacitive loads. 4.4 Supply Bypass 4.5 Unused Op Amps FIGURE 4-3: Unused Op Amps. 4.6 PCB Surface Leakage FIGURE 4-4: Example Guard Ring Layout. 4.7 Application Circuit FIGURE 4-5: Bessel Filter. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Microchip Advanced Part Selector (MAPS) 5.4 Analog Demonstration and Evaluation Boards 5.5 Application Notes 6.0 Packaging Information 6.1 Package Marking Information Appendix A: Revision History Product ID System Trademarks Worldwide Sales
