Datasheet LT1567 (Analog Devices) - 2
Description1.4nV/√Hz 180MHz Filter Building Block
Pages / Page16 / 2 — ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order …
File Format / SizePDF / 208 Kb
ABSOLUTE AXI U. RATI GS. PACKAGE/ORDER I FOR ATIO. (Note 1). Order Options. ELECTRICAL CHARACTERISTICS. The
ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1) Order Options ELECTRICAL CHARACTERISTICS The
LT1567
W W W U U W U ABSOLUTE AXI U RATI GS PACKAGE/ORDER I FOR ATIO (Note 1)
ORDER PART Total Supply Voltage (V+ to V–) .. 12.6V TOP VIEW NUMBER Input Current (Note 2) .. ±25mA OAOUT 1 8 V+ Operating Temperature Range (Note 3) OAIN 2 7 INVOUT LT1567CMS8 LT1567C ..–40°C to 85°C BYPASS 3 6 INVIN 5 DC BIAS LT1567IMS8 V– 4 LT1567I ...–40°C to 85°C MS8 PACKAGE MS8 PART MARKING Specified Temperature Range (Note 4) 8-LEAD PLASTIC MSOP LT1567C ..–40°C to 85°C TJMAX = 150°C, θJA = 200°C/W LTWH LT1567I ...–40°C to 85°C LTWJ Storage Temperature Range ... – 65°C to 150°C
Order Options
Tape and Reel: Add #TR Lead Temperature (Soldering, 10 sec).. 300°C Lead Free: Add #PBF Lead Free Tape and Reel: Add #TRPBF Lead Free Part Marking: http://www.linear.com/leadfree/ Consult LTC Marketing for parts specified with wider operating temperature ranges.
denotes the specifications that apply over the full operating temperature range (Note 4), otherwise specifications and typical values are at TA = 25
C. VS =
2.5V, RL = 1K, VOUT = 0 on both amplifiers unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
Total Supply Voltage 2.7 12 V Supply Current VS = ±1.5V ● 8.5 15 mA VS = ±2.5V ● 9 16 mA VS = ±5V ● 11 19 mA OA Output Positive Voltage Swing VS = ±1.5V, RL = 1k ● 1.30 1.45 V VS = ±2.5V, RL = 1k ● 2.20 2.45 V VS = ±2.5V, RL=100 ● 1.90 2.25 V VS = ±5V, RL = 1k ● 4.70 4.90 V OA Output Negative Voltage Swing VS = ±1.5V, RL = 1k ● –1.30 –1.45 V VS = ±2.5V, RL = 1k ● –2.20 –2.45 V VS = ±2.5V, RL=100 ● –2.00 –2.30 V VS = ±5V, RL = 1k ● –4.70 –4.90 V INV Output Positive Voltage Swing VS = ±1.5V, RL = 1k ● 1.30 1.40 V VS = ±2.5V, RL = 1k ● 2.20 2.50 V VS = ±2.5V, RL = 100 (LT1567I Only, Note 5) ● 1.80 2.00 V VS = ±5V, RL = 1k ● 4.60 4.80 V INV Output Negative Voltage Swing VS = ±1.5V, RL = 1k ● –1.30 –1.40 V VS = ±2.5V, RL = 1k ● –2.20 –2.40 V VS = ±2.5V, RL = 100 (LT1567I Only, Note 5) ● –1.80 –2.00 V VS = ±5V, RL = 1k ● –4.50 –4.80 V Common Mode Input Voltage Range (DC BIAS, Pin 5) VS = ±1.5V, CMRR ≥ 40dB (Note 6) ● –0.5 0.5 V (See Pin Functions) VS = ±5V, CMRR ≥ 40dB (Note 6) ● –3.8 3.5 V DC Common Mode Rejection Ratio (CMRR) VS = ±1.5V, DC BIAS = –0.25V to 0.25V ● 80 dB VS = ±5V, DC BIAS = –2.5V to 2.5V ● 65 90 dB DC Power Supply Rejection Ratio (PSRR) VS = ±1.5V to ±5V, DC BIAS = 0V ● 80 100 dB OA Input Offset Voltage ● 0.5 3 mV INV Output Offset Voltage ● 5 9 mV 1567fa 2
