Datasheet LT1567 (Analog Devices) - 5
Description | 1.4nV/√Hz 180MHz Filter Building Block |
Pages / Page | 16 / 5 — TYPICAL PERFOR A CE CHARACTERISTICS. OA Rising Slew Rate. Output … |
File Format / Size | PDF / 208 Kb |
TYPICAL PERFOR A CE CHARACTERISTICS. OA Rising Slew Rate. Output Overshoot vs Series. Output Impedance vs Frequency
LT1567
W U TYPICAL PERFOR A CE CHARACTERISTICS OA Rising Slew Rate Output Overshoot vs Series Output Impedance vs Frequency vs Temperature Resistor and Capacitive Load
100 60 30 VS = ±5V AV = –1 VS = ±2.5V TA = 25°C RF = RG = 1k VS = ±5V AV = –1 RS = 10Ω RL = 1k 25 RL = ∞ 10 OA ) A 50 Ω V = –10 µs) VS = ±2.5V 20 1 INVERTER 40 15 OA 0.1 R AV = –1 V S = 20Ω S = ±1.5V SLEW RATE (V/ OVERSHOOT (%) 10 RL = ∞ 30 OUTPUT IMPEDANCE ( 0.01 5 RL = RS = 50Ω 0.001 20 0 100k 1M 10M 100M –55 –35 –15 5 25 45 65 85 105 125 10 100 1000 FREQUENCY (Hz) TEMPERATURE (°C) CAPACITIVE LOAD (pF) 1567 G06 1567 G07 1567 G08
Output Overshoot vs Series Input Voltage Noise Density of OA Input Current Noise Density of OA Resistor and Capacitive Load vs Frequency vs Frequency
40 4.5 4.5 T V A = 25°C T S = ±1.5V A = 25°C A 4.0 35 V = –1 4.0 RS = 10Ω RL = ∞ √Hz) √Hz) 3.5 3.5 30 3.0 3.0 25 RS = 20Ω 2.5 2.5 20 RL = ∞ 2.0 2.0 15 OVERSHOOT (%) 1.5 1.5 10 1.0 1.0 RS = RL = 50Ω VOLTAGE NOISE DENSITY (nV/ 5 0.5 CURRENT NOISE DENSITY (pA/ 0.5 0 0 0 10 100 1000 0.1 1 10 100 0.1 1 10 100 CAPACITIVE LOAD (pF) FREQUENCY (kHz) FREQUENCY (kHz) 1567 G10 1567 G11 1567 G09
Input Bias Current of OA vs Common Mode Voltage Supply Current vs Supply Voltage
8 20 VS = 5V 7 µA) 6 15 5 4 10 3 SUPPLY CURRENT (mA) INPUT BIAS CURRENT ( 2 5 1 0 0 0 1 2 3 4 5 0 2 4 6 8 10 COMMON MODE VOLTAGE (V) TOTAL SUPPLY VOLTAGE (V) 1567 G12 1567 G13 1567fa 5
