Datasheet MCP601, MCP601R, MCP602, MCP603, MCP604 (Microchip) - 8
ManufacturerMicrochip
DescriptionMCP601 operational amplifier (op amp) has a gain bandwidth product of 2.8 MHz with low typical operating current of 230 uA and an offset voltage that is less than 2 mV
Pages / Page34 / 8 — MCP601/1R/2/3/4. Note:. 3.5. 100. 130. VDD = 5.0V. 3.0. L = 25 kΩ. GBWP. …
File Format / SizePDF / 600 Kb
MCP601/1R/2/3/4. Note:. 3.5. 100. 130. VDD = 5.0V. 3.0. L = 25 kΩ. GBWP. 120. 2.5. VDD = 5.5V. 110. 2.0. Hz) (M 1.5. PM, G = +1. rgin, G = +1 (°)
MCP601/1R/2/3/4 Note: 3.5 100 130 VDD = 5.0V 3.0 L = 25 kΩ GBWP 120 2.5 VDD = 5.5V 110 2.0 Hz) (M 1.5 PM, G = +1 rgin, G = +1 (°)
Unless otherwise indicated, TA = +25°C, VDD = +2.7V to +5.5V, VSS = GND, VCM = VDD/2, VOUT ≈ VDD/2, VL = VDD/2, RL = 100 kΩ to VL, CL = 50 pF and CS is tied low.
3.5 100 130 VDD = 5.0V 3.0 90 R B) L = 25 kΩ d GBWP 120 2.5 80 VDD = 5.5V 110 2.0 70 Hz) (M 1.5 PM, G = +1 60 rgin, G = +1 (°) Loop Gain ( 100 RL = 5 kΩ 1.0 50 e Ma in Bandwidth Product as 90 a h G 0.5 40 P DC Open- VDD = 2.7V 80 0.0 30 100 1k 10k 100k -50 -25 0 25 50 75 100 125 1.E+02 1.E+03 1.E+04 1.E+05 Load Resistance (Ω) Ambient Temperature (°C) FIGURE 2-19:
Gain Bandwidth Product,
FIGURE 2-22:
DC Open-Loop Gain vs. Phase Margin vs. Load Resistance. Temperature.
1,000 1000 VDD = 5.5V ); ); V SS V SS RL tied to VDD/2 m – V m ( – V R OL 100 m OL 100 L = 5 kΩ V VDD – VOH DD – VOH and V V and V OL – VSS OH OH 10 Headroo 10 put Headroom ( – V – V DD DD RL = 25 kΩ Out V Output V VOL – VSS 1 1 0.01 0.1 1 10 -50 -25 0 25 50 75 100 125 Output Current Magnitude (mA) Ambient Temperature (°C) FIGURE 2-20:
Output Voltage Headroom
FIGURE 2-23:
Output Voltage Headroom vs. Output Current. vs. Temperature.
10 30 V e DD = 5.5V TA = –40°C 25 T ) A = +25°C ) A TA = +85°C P V m 20 P- DD = 2.7V TA = +125°C 1 ude ( 15 Swing (V 10 agnit M imum Output Voltag put Short Circuit Current 5 Max Out 0.1 0 1.E+0 10k 4 1.E 1 + 0 05 0k 1.E 1+06 M 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Frequency (Hz) Supply Voltage (V) FIGURE 2-21:
Maximum Output Voltage
FIGURE 2-24:
Output Short-Circuit Current Swing vs. Frequency. vs. Supply Voltage. DS21314G-page 8 © 2007 Microchip Technology Inc. Document Outline 1.0 Electrical Characteristics FIGURE 1-1: MCP603 Chip Select (CS) Timing Diagram. 1.1 Test Circuits FIGURE 1-2: AC and DC Test Circuit for Most Non-Inverting Gain Conditions. FIGURE 1-3: AC and DC Test Circuit for Most Inverting Gain Conditions. 2.0 Typical Performance Curves FIGURE 2-1: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-2: Slew Rate vs. Temperature. FIGURE 2-3: Gain Bandwidth Product, Phase Margin vs. Temperature. FIGURE 2-4: Quiescent Current vs. Supply Voltage. FIGURE 2-5: Quiescent Current vs. Temperature. FIGURE 2-6: Input Noise Voltage Density vs. Frequency. FIGURE 2-7: Input Offset Voltage. FIGURE 2-8: Input Offset Voltage vs. Temperature. FIGURE 2-9: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 2.7V. FIGURE 2-10: Input Offset Voltage Drift. FIGURE 2-11: CMRR, PSRR vs. Temperature. FIGURE 2-12: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 5.5V. FIGURE 2-13: Channel-to-Channel Separation vs. Frequency. FIGURE 2-14: Input Bias Current, Input Offset Current vs. Ambient Temperature. FIGURE 2-15: DC Open-Loop Gain vs. Load Resistance. FIGURE 2-16: CMRR, PSRR vs. Frequency. FIGURE 2-17: Input Bias Current, Input Offset Current vs. Common Mode Input Voltage. FIGURE 2-18: DC Open-Loop Gain vs. Supply Voltage. FIGURE 2-19: Gain Bandwidth Product, Phase Margin vs. Load Resistance. FIGURE 2-20: Output Voltage Headroom vs. Output Current. FIGURE 2-21: Maximum Output Voltage Swing vs. Frequency. FIGURE 2-22: DC Open-Loop Gain vs. Temperature. FIGURE 2-23: Output Voltage Headroom vs. Temperature. FIGURE 2-24: Output Short-Circuit Current vs. Supply Voltage. FIGURE 2-25: Large Signal Non-Inverting Pulse Response. FIGURE 2-26: Small Signal Non-Inverting Pulse Response. FIGURE 2-27: Chip Select Timing (MCP603). FIGURE 2-28: Large Signal Inverting Pulse Response. FIGURE 2-29: Small Signal Inverting Pulse Response. FIGURE 2-30: Quiescent Current Through VSS vs. Chip Select Voltage (MCP603). FIGURE 2-31: Chip Select Pin Input Current vs. Chip Select Voltage. FIGURE 2-32: Hysteresis of Chip Select’s Internal Switch. FIGURE 2-33: The MCP601/1R/2/3/4 family of op amps shows no phase reversal under input overdrive. FIGURE 2-34: Measured Input Current vs. Input Voltage (below VSS). 3.0 Pin Descriptions TABLE 3-1: Pin Function Table For Single Op Amps TABLE 3-2: Pin Function Table For Dual And Quad Op Amps 3.1 Analog Outputs 3.2 Analog Inputs 3.3 Chip Select Digital Input 3.4 Power Supply Pins 4.0 Applications Information 4.1 Inputs FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. FIGURE 4-3: Unity Gain Buffer has a Limited VOUT Range. 4.2 Rail-to-Rail Output 4.3 MCP603 Chip Select 4.4 Capacitive Loads FIGURE 4-4: Output resistor RISO stabilizes large capacitive loads. FIGURE 4-5: Recommended RISO values for capacitive loads. 4.5 Supply Bypass 4.6 Unused Op Amps FIGURE 4-6: Unused Op Amps. 4.7 PCB Surface Leakage FIGURE 4-7: Example Guard Ring layout. 4.8 Typical Applications FIGURE 4-8: Second-Order, Low-Pass Sallen-Key Filter. FIGURE 4-9: Second-Order, Low-Pass Multiple-Feedback Filter. FIGURE 4-10: Three-Op Amp Instrumentation Amplifier. FIGURE 4-11: Two-Op Amp Instrumentation Amplifier. FIGURE 4-12: Photovoltaic Mode Detector. FIGURE 4-13: Photoconductive Mode Detector. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Mindi™ Simulatior Tool 5.4 MAPS (Microchip Advanced Part Selector) 5.5 Analog Demonstration and Evaluation Boards 5.6 Application Notes 6.0 Packaging Information 6.1 Package Marking Information
