Datasheet AD7605-4 (Analog Devices) - 6
Description4-Channel DAS with 16-Bit, Bipolar Input, Simultaneous Sampling ADC
Pages / Page28 / 6 — Data Sheet. AD7605-4. TIMING SPECIFICATIONS. Table 3. VINL = 0.1 × VDRIVE …
File Format / SizePDF / 811 Kb
Data Sheet. AD7605-4. TIMING SPECIFICATIONS. Table 3. VINL = 0.1 × VDRIVE and. VINL = 0.3 × VDRIVE and. VINH = 0.9 × VDRIVE
Data Sheet AD7605-4 TIMING SPECIFICATIONS Table 3 VINL = 0.1 × VDRIVE and VINL = 0.3 × VDRIVE and VINH = 0.9 × VDRIVE
link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 8 link to page 9
AVCC = 4.75 V to 5.25 V, VDRIVE = 2.3 V to 5.25 V, VREF = 2.5 V external reference/internal reference, TA = TMIN to TMAX, unless otherwise noted. Note that throughout this data sheet, multifunction pins, such as RD/SCLK, are referred to either by the entire pin name or by a single function of the pin, for example, RD, when only that function is relevant.
Table 3. VINL = 0.1 × VDRIVE and VINL = 0.3 × VDRIVE and VINH = 0.9 × VDRIVE VINH = 0.7 × VDRIVE Logic Input Levels Logic Input Levels Parameter Min Typ Max Min Typ Max Unit Description
PARALLEL/SERIAL/BYTE MODE See Figure 2 and Figure 3 tCYCLE 3.33 3.33 μs 1/throughput rate, parallel mode, reading during or after conversion; or serial mode: VDRIVE = 3.3 V to 5.25 V, reading during a conversion using DOUTA and DOUTB lines tCONV 2 2.08 2 2.08 μs Conversion time tWAKE-UP STANDBY 100 100 μs STBY rising edge to CONVST x rising edge; power- up time from standby mode; not shown in Figure 2 or Figure 3 tWAKE-UP SHUTDOWN Not shown in Figure 2 or Figure 3 Internal Reference 30 30 ms STBY rising edge to CONVST x rising edge; power- up time from shutdown mode External Reference 13 13 ms STBY rising edge to CONVST x rising edge; power- up time from shutdown mode tRESET 50 50 ns RESET high pulse width t1 40 45 ns CONVST x high to BUSY high t2 25 25 ns Minimum CONVST x low pulse t3 25 25 ns Minimum CONVST x high pulse t4 0 0 ns BUSY falling edge to CS falling edge setup time t5 0.5 0.5 ms Maximum delay allowed between CONVST A and CONVST B rising edges t6 25 25 ns Maximum time between last CS rising edge and BUSY falling edge t7 25 25 ns Minimum delay between RESET low to CONVST x high PARALLEL/BYTE READ See Figure 4, Figure 5, and Figure 7 OPERATION t8 0 0 ns CS to RD setup time t9 0 0 ns CS to RD hold time t10 RD low pulse width 16 19 ns VDRIVE above 4.75 V 21 24 ns VDRIVE above 3.3 V 25 30 ns VDRIVE above 2.7 V 32 37 ns VDRIVE above 2.3 V t11 15 15 ns RD high pulse width t12 22 22 ns CS high pulse width; CS and RD linked t13 Delay from CS until DB15 to DB0 three-state disabled 16 19 ns VDRIVE above 4.75 V 20 24 ns VDRIVE above 3.3 V 25 30 ns VDRIVE above 2.7 V 30 37 ns VDRIVE above 2.3 V t14 Data access time after RD falling edge 16 19 ns VDRIVE above 4.75 V 21 24 ns VDRIVE above 3.3 V 25 30 ns VDRIVE above 2.7 V 32 37 ns VDRIVE above 2.3 V Rev. 0 | Page 5 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CONVERTER DETAILS ANALOG INPUT Analog Input Ranges Analog Input Impedance Analog Input Clamp Protection Analog Input Antialiasing Filter Track-and-Hold Amplifiers ADC TRANSFER FUNCTION INTERNAL/EXTERNAL REFERENCE TYPICAL CONNECTION DIAGRAM POWER-DOWN MODES CONVERSION CONTROL Simultaneous Sampling on All Analog Input Channels Simultaneously Sampling Two Sets of Channels APPLICATIONS INFORMATION PARALLEL INTERFACE (/SER/BYTE SEL = 0) PARALLEL BYTE (/SER/BYTE SEL = 1, DB15/BYTE SEL = 1) SERIAL INTERFACE (/SER/BYTE SEL = 1) READING DURING CONVERSION LAYOUT GUIDELINES OUTLINE DIMENSIONS ORDERING GUIDE
