Datasheet LF253, LF353 (STMicroelectronics)
DescriptionWide bandwidth dual JFET operational amplifiers
Pages / Page15 / 1 — LF253, LF353. Features. DIP8. Description. SO-8. Pin connections
Revision3.1
File Format / SizePDF / 925 Kb
Datasheet LF253, LF353 STMicroelectronics, Revision: 3.1
LF253, LF353
Features
■ Low power consumption ■ Wide common-mode (up to V + CC ) and differential voltage range ■ Low input bias and offset current
N DIP8
■ Output short-circuit protection (Plastic package) ■ High input impedance JFET input stage ■ Internal frequency compensation ■ Latch up free operation ■ High slew rate 16 V/µs (typical)
D Description SO-8
(Plastic micro package) These circuits are high speed JFET input dual operational amplifiers incorporating well matched,
Pin connections
high voltage JFET and bipolar transistors in a (top view) monolithic integrated circuit. The devices feature high slew rates, low input bias and offset currents, and low offset voltage 1 8 temperature coefficient. 2 - 7 3 + - 6 4 + 5 1 - Output1 2 - Inverting input 1 3 - Non-inverting input 1 4 - V - CC 5 - Non-inverting input 2 6 - Inverting input 2 7 - Output 2 8 - V + CC March 2010 Doc ID 2153 Rev 3 1/15 www.st.com 15 Document Outline 1 Schematics Figure 1. Schematic diagram (each amplifier) 2 Absolute maximum ratings and operating conditions Table 1. Absolute maximum ratings Table 2. Operating conditions 3 Electrical characteristics Table 3. Electrical characteristics at VCC = ±15 V, Tamb = +25˚C (unless otherwise specified) Figure 2. Maximum peak-to-peak output voltage vs. frequency, RL = 2 kW Figure 3. Maximum peak-to-peak output voltage vs. frequency, RL = 10 kW Figure 4. Maximum peak-to-peak output voltage versus frequency Figure 5. Maximum peak-to-peak output voltage versus free air temperature Figure 6. Maximum peak-to-peak output voltage versus load resistance Figure 7. Maximum peak-to-peak output voltage versus supply voltage Figure 8. Input bias current versus free air temperature Figure 9. Large signal differential voltage amplification versus free air temp. Figure 10. Large signal differential voltage amplification and phase shift versus frequency Figure 11. Total power dissipation versus free air temperature Figure 12. Supply current per amplifier versus free air temperature Figure 13. Supply current per amplifier versus supply voltage Figure 14. Common mode rejection ratio versus free air temperature Figure 15. Voltage follower large signal pulse response Figure 16. Output voltage versus elapsed time Figure 17. Equivalent input noise voltage versus frequency Figure 18. Total harmonic distortion versus frequency 4 Parameter measurement information Figure 19. Voltage follower Figure 20. Gain of 10 inverting amplifier 5 Typical application Figure 21. Quadruple oscillator 6 Package information 6.1 DIP8 package information Figure 22. DIP8 package mechanical drawing Table 4. DIP8 package mechanical data 6.2 SO-8 package information Figure 23. SO-8 package mechanical drawing Table 5. SO-8 package mechanical data 7 Ordering information Table 6. Order codes 8 Revision history Table 7. Document revision history
