Datasheet ADA4077-1, ADA4077-2, ADA4077-4 (Analog Devices) - 6
Description4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Single Amplifier
Pages / Page27 / 6 — ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. Parameter. Symbol. Test …
RevisionE
File Format / SizePDF / 987 Kb
ADA4077-1/ADA4077-2/ADA4077-4. Data Sheet. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max. Unit
ADA4077-1/ADA4077-2/ADA4077-4 Data Sheet Parameter Symbol Test Conditions/Comments Min Typ Max Unit
POWER SUPPLY Power Supply Rejection Ratio PSRR VS = ±2.5 V to ±18 V 123 128 dB −40°C < TA < +125°C 120 dB Supply Current per Amplifier ISY VO = 0 V 400 500 µA −40°C < TA < +125°C 650 µA DYNAMIC PERFORMANCE Slew Rate SR RL = 2 kΩ 1.2 V/µs Settling Time to 0.01% ts VIN = 10 V p-p, RL = 2 kΩ, AV = −1 16 µs Settling Time to 0.1% ts VIN = 10 V p-p, RL = 2 kΩ, AV = −1 10 µs Gain Bandwidth Product GBP VIN = 10 mV p-p, RL = 2 kΩ, AV = +100 3.6 MHz Unity-Gain Crossover UGC VIN = 10 mV p-p, RL = 2 kΩ, AV = +1 3.9 MHz −3 dB Closed-Loop Bandwidth −3 dB AV = +1, VIN = 10 mV p-p, RL = 2 kΩ 5.5 MHz Phase Margin ΦM VIN = 10 mV p-p, RL = 2 kΩ, AV = +1 58 Degrees Total Harmonic Distortion Plus Noise THD + N VIN = 1 V rms, AV = +1, RL = 2 kΩ, 0.004 % f = 1 kHz NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.25 µV p-p Voltage Noise Density en f = 1 Hz 13 nV/√Hz f = 100 Hz 7 nV/√Hz f = 1000 Hz 6.9 nV/√Hz Current Noise Density in f = 1 kHz 0.2 pA/√Hz MULTIPLE AMPLIFIERS CHANNEL SEPARATION CS f = 1 kHz, RL = 10 kΩ −125 dB Rev. E | Page 6 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL LOW POWER LINEARIZED RTD PROPER BOARD LAYOUT LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
