Datasheet ADA4077-1, ADA4077-2, ADA4077-4 (Analog Devices) - 7
Description4 MHz, 7 nV/√Hz, Low Offset and Drift, High Precision Single Amplifier
Pages / Page27 / 7 — Data Sheet. ADA4077-1/ADA4077-2/ADA4077-4. ABSOLUTE MAXIMUM RATINGS Table …
RevisionE
File Format / SizePDF / 987 Kb
Data Sheet. ADA4077-1/ADA4077-2/ADA4077-4. ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE. Parameter. Rating
Data Sheet ADA4077-1/ADA4077-2/ADA4077-4 ABSOLUTE MAXIMUM RATINGS Table 4 THERMAL RESISTANCE Parameter Rating
Data Sheet ADA4077-1/ADA4077-2/ADA4077-4 ABSOLUTE MAXIMUM RATINGS Table 4. THERMAL RESISTANCE Parameter Rating
θJA is specified for the worst case conditions, that is, a device Supply Voltage 36 V soldered in a circuit board for surface-mount packages. Input Voltage ±VSY Input Current1 ±10 mA
Table 5. Thermal Resistance
Differential Input Voltage ±V
Package Type θJA θJC Unit
SY Output Short-Circuit Duration to GND Indefinite 8-Lead MSOP 190 44 °C/W Storage Temperature Range −65°C to +150°C 8-Lead SOIC 158 43 °C/W Operating Temperature Range −40°C to +125°C 14-Lead TSSOP 240 43 °C/W Junction Temperature Range −65°C to +150°C 14-Lead SOIC 115 36 °C/W Maximum Reflow Temperature (MSL1 Rating)2 260°C Lead Temperature, Soldering (10 sec) 300°C
ESD CAUTION
Electrostatic Discharge (ESD) Human Body Model (HBM)3 6 kV Field Induced Charge Device Model (FICDM)4 1.25 kV 1 The input pins have clamp diodes to the power supply pins and to each other. Limit the input current to 10 mA or less whenever input signals exceed the power supply rail by 0.3 V. 2 IPC/JEDEC J-STD-020 applicable standard. 3 ESDA/JEDEC JS-001-2011 applicable standard. 4 JESD22-C101 (ESD FICDM standard of JEDEC) applicable standard. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. E | Page 7 of 27 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, ±5 V ELECTRICAL CHARACTERISTICS, ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION APPLICATIONS INFORMATION OUTPUT PHASE REVERSAL LOW POWER LINEARIZED RTD PROPER BOARD LAYOUT LONG-TERM DRIFT TEMPERATURE HYSTERESIS OUTLINE DIMENSIONS ORDERING GUIDE
