Datasheet ADA4895-1, ADA4895-2 (Analog Devices) - 9
Description | Low Power, 1 nV/√Hz, G ≥ 10 Stable, Rail-to-Rail Output Amplifier |
Pages / Page | 24 / 9 — Data Sheet. ADA4895-1/ADA4895-2. OUT1. 10 +VS. –IN1. OUT2. +IN1. –IN2. … |
Revision | B |
File Format / Size | PDF / 599 Kb |
Data Sheet. ADA4895-1/ADA4895-2. OUT1. 10 +VS. –IN1. OUT2. +IN1. –IN2. –VS 4. +IN2. DISABLE1. ADA4895-2. DISABLE2
Data Sheet ADA4895-1/ADA4895-2 OUT1 1 10 +VS –IN1 2 9 OUT2 +IN1 3 8 –IN2 –VS 4 7 +IN2
004
DISABLE1 5 ADA4895-2 6 DISABLE2
10186- Figure 7. 10-Lead MSOP Pin Configuration for the ADA4895-2
Table 9. 10-Lead MSOP Pin Function Descriptions for the ADA4895-2 Pin Number Mnemonic Description
1 OUT1 Output 1 2 −IN1 Inverting Input 1 3 +IN1 Noninverting Input 1 4 −VS Negative Supply 5 DISABLE1 Disable 1 6 DISABLE2 Disable 2 7 +IN2 Noninverting Input 2 8 −IN2 Inverting Input 2 9 OUT2 Output 2 10 +VS Positive Supply Rev. B | Page 9 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS COMPANION PRODUCTS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V (OR +10 V) SUPPLY ±2.5 V (OR +5 V) SUPPLY ±1.5 V (OR +3 V) SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION AMPLIFIER DESCRIPTION INPUT PROTECTION DISABLE OPERATION DC ERRORS BIAS CURRENT CANCELLATION NOISE CONSIDERATIONS APPLICATIONS INFORMATION USING THE ADA4895-1/ADA4895-2 AT A GAIN < +10 HIGH GAIN BANDWIDTH APPLICATION FEEDBACK CAPACITOR APPLICATION WIDEBAND PHOTOMULTIPLIER PREAMPLIFIER LAYOUT CONSIDERATIONS Ground Plane Power Supply Bypassing OUTLINE DIMENSIONS ORDERING GUIDE
