Datasheet ADA4312-1 (Analog Devices) - 9
DescriptionWideband, Differential, High Output Current Line Driver with Shutdown
Pages / Page13 / 9 — ADA4312-1. Data Sheet. TEST CIRCUIT. 1.1Ω. 732Ω. 1.5kΩ. VMID. 97.6Ω. …
RevisionA
File Format / SizePDF / 479 Kb
ADA4312-1. Data Sheet. TEST CIRCUIT. 1.1Ω. 732Ω. 1.5kΩ. VMID. 97.6Ω. 40.2Ω. IADJ
ADA4312-1 Data Sheet TEST CIRCUIT 1.1Ω 732Ω 1.5kΩ VMID 97.6Ω 40.2Ω IADJ
ADA4312-1 Data Sheet TEST CIRCUIT + 1.1Ω ADA4312-1 732Ω 1.5kΩ VMID 97.6Ω 40.2Ω 1.5kΩ 732Ω ADA4312-1 1.1Ω + R
019
IADJ
11044- Figure 16. Test Circuit, RIADJ = 0 Ω Rev. A | Page 8 of 12 Document Outline Features Applications General Description Functional Block Diagram Typical Application Circuit Revision History Specifications Absolute Maximum Ratings Thermal Resistance Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuit Applications Information Feedback Resistor Selection General Operation Half-Duplex Operation Establishing VMID Bias Control and Linearity PCB Layout Thermal Management Power Supply Bypassing Evaluation Board Outline Dimensions Ordering Guide
