Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 4
Description30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Quad Op Amplifier
Pages / Page24 / 4 — ADA4096-2/ADA4096-4. Data Sheet. ELECTRICAL SPECIFICATIONS, VSY = ±5 V. …
RevisionG
File Format / SizePDF / 676 Kb
ADA4096-2/ADA4096-4. Data Sheet. ELECTRICAL SPECIFICATIONS, VSY = ±5 V. Table 3. Parameter. Symbol. Test Conditions/Comments. Min
ADA4096-2/ADA4096-4 Data Sheet ELECTRICAL SPECIFICATIONS, VSY = ±5 V Table 3 Parameter Symbol Test Conditions/Comments Min
VSY = ±5 V, VCM = VSY/2, TA = 25°C, unless otherwise noted.
Table 3. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 35 300 µV −40°C ≤ TA ≤ +125°C 500 µV Offset Voltage Drift ∆VOS/∆T 1 µV/°C Input Bias Current IB ±10 ±25 nA −40°C ≤ TA ≤ +125°C ±30 nA Input Offset Current IOS ±1.5 ±2 nA −40°C ≤ TA ≤ +125°C ±3 nA Input Voltage Range −5 +5 V Common-Mode Rejection Ratio CMRR VCM = −5 V to +5 V 72 86 dB −40°C ≤ TA ≤ +125°C 68 dB VCM = −3 V to +3 V 91 103 dB −40°C ≤ TA ≤ +125°C 85 dB Large Signal Voltage Gain AVO RL = 10 kΩ, VO = ±4.8 V 102 111 dB −40°C ≤ TA ≤ +125°C 99 dB RL = 2 kΩ, VO = ±4.7 V 93 103 dB −40°C ≤ TA ≤ +125°C 88 dB MATCHING CHARACTERISTICS Offset Voltage TA = 25°C 100 300 µV OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to GND 4.96 4.97 V −40°C ≤ TA ≤ +125°C 4.95 V RL = 2 kΩ to GND 4.80 4.90 V −40°C ≤ TA ≤ +125°C 4.70 V Output Voltage Low VOL RL = 10 kΩ to GND −4.98 −4.97 V −40°C ≤ TA ≤ +125°C −4.95 V RL = 2 kΩ to GND −4.90 −4.80 V −40°C ≤ TA ≤ +125°C −4.75 V Short-Circuit Limit ISC Source/sink ±10 mA Closed-Loop Impedance ZOUT f = 100 kHz, AV = 1 71 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 3 V to 36 V 100 dB −40°C ≤ TA ≤ +125°C 90 dB Supply Current per Amplifier ISY VO = VSY/2 47 55 µA −40°C ≤ TA ≤ +125°C 75 µA DYNAMIC PERFORMANCE Slew Rate SR RL = 100 kΩ, CL = 30 pF 0.3 V/µs Gain Bandwidth Product GBP VIN = 5 mV p-p, RL = 10 kΩ, AV = 100 595 kHz Unity-Gain Crossover UGC VIN = 5 mV p-p, RL = 10 kΩ, AV = 1 550 kHz Phase Margin ΦM 52 Degrees −3 dB Closed-Loop Bandwidth f−3 dB AV = 1, VIN = 5 mV p-p 1140 kHz NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.7 µV p-p Voltage Noise Density en f = 1 kHz 27 nV/√Hz Current Noise Density in f = 1 kHz 0.2 pA/√Hz Rev. F | Page 4 of 24 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS, VSY = ±1.5 V ELECTRICAL SPECIFICATIONS, VSY = ±5 V ELECTRICAL SPECIFICATIONS, VSY = ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS THEORY OF OPERATION INPUT STAGE PHASE INVERSION INPUT OVERVOLTAGE PROTECTION COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
