Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 5
Description30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Quad Op Amplifier
Pages / Page24 / 5 — Data Sheet. ADA4096-2/ADA4096-4. ELECTRICAL SPECIFICATIONS, VSY = ±15 V. …
RevisionG
File Format / SizePDF / 676 Kb
Data Sheet. ADA4096-2/ADA4096-4. ELECTRICAL SPECIFICATIONS, VSY = ±15 V. Table 4. Parameter. Symbol. Test Conditions/Comments. Min
Data Sheet ADA4096-2/ADA4096-4 ELECTRICAL SPECIFICATIONS, VSY = ±15 V Table 4 Parameter Symbol Test Conditions/Comments Min
VSY = ±15 V, VCM = VSY/2, VO = 0.0 V, TA = 25°C, unless otherwise noted.
Table 4. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
INPUT CHARACTERISTICS Offset Voltage VOS 35 300 µV −40°C ≤ TA ≤ +125°C 500 µV Offset Voltage Drift ∆VOS/∆T 1 µV/°C Input Bias Current IB ±3 ±25 nA −40°C ≤ TA ≤ +125°C ±30 nA Input Offset Current IOS ±0.1 ±1.5 nA −40°C ≤ TA ≤ +125°C ±3 nA Input Voltage Range −15 +15 V Common-Mode Rejection Ratio CMRR VCM = −15 V to +15 V 81 95 dB −40°C ≤ TA ≤ +125°C 75 dB VCM = −13 V to +13 V 95 107 dB −40°C ≤ TA ≤ +125°C 89 dB Large Signal Voltage Gain AVO RL = 10 kΩ, VO = ±14.7 V 109 120 dB −40°C ≤ TA ≤ +125°C 105 dB RL = 2 kΩ, VO = ±11 V 99 112 dB −40°C ≤ TA ≤ +125°C 90 dB Input Capacitance Differential Mode CDM 2.5 pF Common Mode CCM 7 pF MATCHING CHARACTERISTICS Offset Voltage TA = 25°C 100 300 µV OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to GND 14.92 14.94 V −40°C ≤ TA ≤ +125°C 14.90 V RL = 2 kΩ to GND 14.0 14.3 V −40°C ≤ TA ≤ +125°C 11.0 V Output Voltage Low VOL RL = 10 kΩ to GND −14.96 −14.80 V −40°C ≤ TA ≤ +125°C −14.75 V RL = 2 kΩ to GND −14.75 −14.60 V −40°C ≤ TA ≤ +125°C −14.0 V Short-Circuit Limit ISC Source/sink ±10 mA Closed-Loop Impedance ZOUT f = 100 kHz, AV = 1 40 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 3 V to 36 V 100 dB −40°C ≤ TA ≤ +125°C 90 dB Supply Current per Amplifier ISY VO = VSY/2 60 75 µA −40°C ≤ TA ≤ +125°C 100 µA DYNAMIC PERFORMANCE Slew Rate SR RL = 100 kΩ, CL = 30 pF 0.4 V/µ Settling Time tS To 0.1%, 10 V step 23.4 µs Gain Bandwidth Product GBP VIN = 5 mV p-p, RL = 10 kΩ, AV = 100 786 kHz Unity-Gain Crossover UGC VIN = 5 mV p-p, RL = 10 kΩ, AV = 1 800 kHz Phase Margin ΦM 60 Degrees −3 dB Closed-Loop Bandwidth f−3 dB AV = 1, VIN = 5 mV p-p 1520 kHz Channel Separation CS f = 1 kHz 100 dB NOISE PERFORMANCE Voltage Noise en p-p 0.1 Hz to 10 Hz 0.7 µV p-p Voltage Noise Density en f = 1 kHz 27 nV/√Hz Current Noise Density in f = 1 kHz 0.2 pA/√Hz Rev. F | Page 5 of 24 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS, VSY = ±1.5 V ELECTRICAL SPECIFICATIONS, VSY = ±5 V ELECTRICAL SPECIFICATIONS, VSY = ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS THEORY OF OPERATION INPUT STAGE PHASE INVERSION INPUT OVERVOLTAGE PROTECTION COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
