Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 6
Description30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Quad Op Amplifier
Pages / Page24 / 6 — ADA4096-2/ADA4096-4. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. …
RevisionG
File Format / SizePDF / 676 Kb
ADA4096-2/ADA4096-4. Data Sheet. ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE. Parameter Rating
ADA4096-2/ADA4096-4 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5 THERMAL RESISTANCE Parameter Rating
ADA4096-2/ADA4096-4 Data Sheet ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE Parameter Rating
θJA is specified for the device soldered on a 4-layer JEDEC Supply Voltage 36 V standard printed circuit board (PCB) with zero airflow. The Input Voltage exposed pad is soldered to the application board. Operating Condition −V ≤ VIN ≤ +V
Table 6. Thermal Resistance
Overvoltage Condition1 (−V) − 32 V ≤ VIN ≤ (+V) + 32 V Differential Input Voltage2 ±V
Package Type θJA θJC Unit
SY Input Current ±5 mA 8-Lead MSOP (RM-8) 142 45 °C/W Output Short-Circuit Duration to Indefinite 8-Lead LFCSP (CP-8-10) 76 43 °C/W GND 14-Lead TSSOP (RU-14) 112 35 °C/W Storage Temperature Range −65°C to +150°C 16-Lead LFCSP (CP-16-27) 75 12 °C/W Operating Temperature Range −40°C to +125°C Junction Temperature Range −65°C to +150°C
ESD CAUTION
Lead Temperature (Soldering, 300°C 60 seconds) 1 Performance not guaranteed during overvoltage conditions. 2 Limit the input current to ±5 mA. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. F | Page 6 of 24 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS, VSY = ±1.5 V ELECTRICAL SPECIFICATIONS, VSY = ±5 V ELECTRICAL SPECIFICATIONS, VSY = ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS THEORY OF OPERATION INPUT STAGE PHASE INVERSION INPUT OVERVOLTAGE PROTECTION COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
