Datasheet ADA4096-2, ADA4096-4 (Analog Devices) - 9
Description30 V, Micropower, Overvoltage Protection, Rail-to-Rail Input/Output Quad Op Amplifier
Pages / Page24 / 9 — Data Sheet. ADA4096-2/ADA4096-4. TYPICAL PERFORMANCE CHARACTERISTICS. …
RevisionG
File Format / SizePDF / 676 Kb
Data Sheet. ADA4096-2/ADA4096-4. TYPICAL PERFORMANCE CHARACTERISTICS. ±1.5 V CHARACTERISTICS. 180. ADA4096-2. 160. VSY = ±1.5V
Data Sheet ADA4096-2/ADA4096-4 TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS 180 ADA4096-2 160 VSY = ±1.5V
TA = 25°C, unless otherwise noted. Al typical performance characteristics shown are for the ADA4096-2 only.
±1.5 V CHARACTERISTICS 180 30 ADA4096-2 ADA4096-2 160 VSY = ±1.5V VSY = ±1.5V TA = 25°C 20 140 RS 10 IE 120 IF TA = +25°C L TA = +125°C P 100 0 A) AM n TA = +85°C F ( 80 I B –10 R O BE T 60 A = 0°C –20 NUM 40 –30 20 TA = –40°C 0 –40 0 25 50 75 –1.5 –1.0 –0.5 0 0.5 1.0 1.5
005
–75 –50 –25 100 125 150 175 200 RE –200 –175 –150 –125 –100 O
003
M VCM (V) V
09241-
OS (µV)
09241- Figure 8. Input Offset Voltage (VOS) Distribution Figure 11. Input Bias Current (IB) vs. VCM for Various Temperatures
25 10k ADA4096-2 ADA4096-2 ) VSY = ±1.5V V VSY = ±1.5V T m A = –40°C TO +125°C TA = 25°C 20 IL ( A 1k RS R IE LY IF P L 15 P P U AM F 100 TO S R O 10 GE BE SOURCING OLTA NUM T V 10 SINKING 5 U TP OU 0 1 –2.5 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 0.001 0.01 0.1 1 10 100
006 004
LOAD CURRENT (mA)
09241-
TCVOS (µV/°C)
09241- Figure 9. Offset Voltage Drift (TCVOS) Distribution Figure 12. Output Voltage to Supply Rail vs. Load Current
800 140 200 ADA4096-2 V 600 120 SY = ±1.5V TA = 25°C 150 100 400 PHASE 80 100 200 60 V) B) rees) µ d ( 0 40 50 Deg N ( OS ( V AI GAIN E G –200 20 HAS 0 P 0 –400 –20 –50 –600 VSY = ±1.5V
210
10 CHANNELS –40 –800
09241-
–60 –100 –1.5 –1.3 –1.0 –0.8 –0.5 –0.3 0 0.3 0.5 0.8 1.0 1.3 1.5 100 1k 10k 100k 1M 10M
007
VCM (V) FREQUENCY (Hz)
09241- Figure 10. Input Offset Voltage (VOS) vs. Common-Mode Voltage (VCM) Figure 13. Open-Loop Gain and Phase vs. Frequency Rev. F | Page 9 of 24 Document Outline FEATURES APPLICATIONS PIN CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS, VSY = ±1.5 V ELECTRICAL SPECIFICATIONS, VSY = ±5 V ELECTRICAL SPECIFICATIONS, VSY = ±15 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ±1.5 V CHARACTERISTICS ±5 V CHARACTERISTICS ±15 V CHARACTERISTICS COMPARATIVE VOLTAGE AND VARIABLE VOLTAGE GRAPHS THEORY OF OPERATION INPUT STAGE PHASE INVERSION INPUT OVERVOLTAGE PROTECTION COMPARATOR OPERATION OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
