Datasheet ADA4800 (Analog Devices) - 2
DescriptionLow Power, High Speed CCD Buffer Amplifier
Pages / Page17 / 2 — ADA4800* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. …
RevisionA
File Format / SizePDF / 244 Kb
ADA4800* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017. COMPARABLE PARTS. DISCUSSIONS. DOCUMENTATION. SAMPLE AND BUY
ADA4800* PRODUCT PAGE QUICK LINKS Last Content Update: 02/23/2017 COMPARABLE PARTS DISCUSSIONS DOCUMENTATION SAMPLE AND BUY
View a parametric search of comparable parts. View all ADA4800 EngineerZone Discussions.
DOCUMENTATION SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • ADA4800: Low-Power High Speed CCD Buffer Amplifier Data Sheet
TECHNICAL SUPPORT
Submit a technical question or find your regional support
DESIGN RESOURCES
number. • ADA4800 Material Declaration • PCN-PDN Information
DOCUMENT FEEDBACK
• Quality And Reliability Submit feedback for this data sheet. • Symbols and Footprints
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS BUFFER ELECTRICAL CHARACTERISTICS ACTIVE CURRENT LOAD ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUIT THEORY OF OPERATION SETTING ACTIVE LOAD CURRENT WITH PIN 6 (ISF) SETTING BANDWIDTH WITH PIN 4 (IDRV) APPLICATIONS INFORMATION OPEN SOURCE CCD OUTPUT BUFFER POWER SAVE MODE POWER SUPPLY BYPASSING POWER SEQUENCING OUTLINE DIMENSIONS ORDERING GUIDE
