Datasheet ADA4627-1, ADA4637-1 (Analog Devices) - 7
Description30 V, 80 MHz, Low Noise, Low Bias Current, JFET Op Amp
Pages / Page20 / 7 — Data Sheet. ADA4627-1/ADA4637-1. 120. 100. d ( 110 IO. N RAT IO. B) d. RR …
RevisionF
File Format / SizePDF / 793 Kb
Data Sheet. ADA4627-1/ADA4637-1. 120. 100. d ( 110 IO. N RAT IO. B) d. RR ( S. PSRR–. PSRR+. M N- O. ADA4627-1. A = 25°C. VSY = ±15V. SY = ±15V
Data Sheet ADA4627-1/ADA4637-1 120 100 d ( 110 IO N RAT IO B) d RR ( S PSRR– PSRR+ M N- O ADA4627-1 A = 25°C VSY = ±15V SY = ±15V
Data Sheet ADA4627-1/ADA4637-1 120 120 B) 100 d ( 110 IO 80 100 N RAT IO B) d CT 60 JE 90 RR ( S PSRR– RE P PSRR+ DE 40 O 80 M N- O ADA4627-1 M ADA4627-1 20 T M 70 A = 25°C VSY = ±15V V CO SY = ±15V VCM = ±11.5V 0 60
009
100 1k 10k 100k 1M 10M –50 –25 0 25 50 75 100 125
012
FREQUENCY (Hz)
07559-
TEMPERATURE (°C)
07559- Figure 10. PSRR vs. Frequency Figure 13. CMRR vs. Temperature
8 20 –40ºC ADA4627-1 7 TA = 25°C VSY = ±15V 6 +25ºC +85ºC +125ºC 10 mA) ( 5 NT (V) SS 4 – V CURRE Y OL L 3 V P UP S 2 ADA4627-1 1
058
0 1
07559-
0 4 8 12 16 20 24 28 32 36
011
0.001 0.01 0.1 1 10 100 SUPPLY VOLTAGE (V) I
07559-
LOAD (mA)
Figure 11. Supply Current vs. Supply Voltage and Temperature Figure 14. VOUT Sinking vs. ILOAD Current
120 20 ADA4627-1 TA = 25°C VSY = ±15V 10 (V) B) (d OH 110 – V RR S P DDV ADA4627-1 RL = ∞ ±4.5V < V
057
SY < ±18V
068
100
07559-
1
07559-
–40 –20 0 20 40 60 80 100 120 0.001 0.01 0.1 1 10 100 TEMPERATURE (°C) ILOAD (mA)
Figure 12. PSRR vs. Temperature Figure 15. VOUT Sourcing vs. ILOAD Current Rev. F | Page 7 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—30 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT VOLTAGE RANGE INPUT OFFSET VOLTAGE ADJUST RANGE INPUT BIAS CURRENT NOISE CONSIDERATIONS THD + N MEASUREMENTS PRINTED CIRCUIT BOARD LAYOUT, BIAS CURRENT, AND BYPASSING OUTPUT PHASE REVERSAL DECOMPENSATED OP AMPS DRIVING CAPACITIVE LOADS OUTLINE DIMENSIONS ORDERING GUIDE
