Datasheet AD8622, AD8624 (Analog Devices) - 5
DescriptionLow Power, Precision Rail-to-Rail Output Op Amp
Pages / Page20 / 5 — Data Sheet. AD8622/AD8624. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. …
RevisionD
File Format / SizePDF / 604 Kb
Data Sheet. AD8622/AD8624. ABSOLUTE MAXIMUM RATINGS. Table 2. Parameter. Rating. THERMAL RESISTANCE. Table 3. Thermal Resistance
Data Sheet AD8622/AD8624 ABSOLUTE MAXIMUM RATINGS Table 2 Parameter Rating THERMAL RESISTANCE Table 3 Thermal Resistance
link to page 5 link to page 5
Data Sheet AD8622/AD8624 ABSOLUTE MAXIMUM RATINGS Table 2. Parameter Rating THERMAL RESISTANCE
Supply Voltage ±18 V θJA is specified for the worst-case conditions, that is, a device Input Voltage ±VSY soldered in a circuit board for surface-mount packages. This Input Current1 ±10 mA was measured using a standard 4-layer board. Differential Input Voltage2 ±10 V Output Short-Circuit Duration to GND Indefinite
Storage Temperature Range −65°C to +150°C
Package Type θJA θJC Unit
Operating Temperature Range −40°C to +125°C 8-Lead SOIC_N (R-8) 120 45 °C/W Junction Temperature Range −65°C to +150°C 8-Lead MSOP (RM-8) 142 45 °C/W Lead Temperature (Soldering, 60 sec) 300°C 14-Lead TSSOP (RU-14) 112 35 °C/W 16-Lead LFCSP (CP-16-17) 55 14 °C/W 1 The input pins have clamp diodes to the power supply pins. The input current should be limited to 10 mA or less whenever input signals exceed the power supply rail by 0.5 V.
ESD CAUTION
2 Differential input voltage is limited to 10 V or the supply voltage, whichever is less. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Rev. D | Page 5 of 20 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics—±2.5 V Operation Electrical Characteristics—±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Protection Phase Reversal Micropower Instrumentation Amplifier Hall Sensor Signal Conditioning Simplified Schematic Outline Dimensions Ordering Guide
