Datasheet AD8622, AD8624 (Analog Devices) - 6
DescriptionLow Power, Precision Rail-to-Rail Output Op Amp
Pages / Page20 / 6 — AD8622/AD8624. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. VSY = …
RevisionD
File Format / SizePDF / 604 Kb
AD8622/AD8624. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. VSY = ±2.5V. VSY = ±15V. VCM = 0V. R O. NUM. –100. –80. –60. –40. –20. 100
AD8622/AD8624 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS VSY = ±2.5V VSY = ±15V VCM = 0V R O NUM –100 –80 –60 –40 –20 100
TA = 25°C, unless otherwise noted.
60 60 VSY = ±2.5V VSY = ±15V VCM = 0V VCM = 0V 50 50 RS RS IE 40 IE 40 IF IF L L P P AM 30 AM 30 F F R O R O BE 20 BE 20 NUM NUM 10 10 0 0 –100 –80 –60 –40 –20 0 20 40 60 80 100
065
063
VOS (µV) V
07527-
OS (µV)
07527- Figure 5. Input Offset Voltage Distribution Figure 8. Input Offset Voltage Distribution
60 60 VSY = ±2.5V VSY = ±15V –40°C ≤ TA ≤ +125°C –40°C ≤ TA ≤ +125°C 50 50 RS RS IE 40 IE 40 IF IF L L P P AM 30 AM 30 F F R O R O BE 20 BE 20 NUM NUM 10 10 0 0 0 0.2 0.4 0.6 0.8 1.0 1.2
066
064
TCVOS (µV/°C) TCV
07527-
OS (µV/°C)
07527- Figure 6. Input Offset Voltage Drift Distribution Figure 9. Input Offset Voltage Drift Distribution
50 50 VSY = ±2.5V VSY = ±15V 40 40 –40°C 30 30 20 20 –40°C 10 10 V) V) +25°C 0 0 OS OS V V +25°C –10 –10 +85°C +85°C –20 –20 +125°C +125°C –30 –30 –40 –40 –50 –50 –2.5 –1.5 –0.5 0.5 1.5 2.5
007
–15 –10 –5 0 5 10 +15
004
V V CM (V)
07527-
CM (V)
07527- Figure 7. Input Offset Voltage vs. Common-Mode Voltage Figure 10. Input Offset Voltage vs. Common-Mode Voltage Rev. D | Page 6 of 20 Document Outline Features Applications General Description Pin Configurations Table of Contents Revision History Specifications Electrical Characteristics—±2.5 V Operation Electrical Characteristics—±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Protection Phase Reversal Micropower Instrumentation Amplifier Hall Sensor Signal Conditioning Simplified Schematic Outline Dimensions Ordering Guide
