Datasheet ADA4051-1, ADA4051-2 (Analog Devices) - 8
Description | 1.8 V, µpower, Zero-Drift, RRIO Single Amplifier |
Pages / Page | 22 / 8 — ADA4051-1/ADA4051-2. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. … |
Revision | C |
File Format / Size | PDF / 663 Kb |
ADA4051-1/ADA4051-2. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 300. VSY = 1.8V. VSY = 5V. VCM = VSY/2. 250. 200. LIFIE. 150. R O. 100. NUM
ADA4051-1/ADA4051-2 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
TA = 25°C, unless otherwise noted.
300 300 VSY = 1.8V VSY = 5V VCM = VSY/2 VCM = VSY/2 250 250 S S R R 200 200 LIFIE LIFIE P P M M A 150 A F 150 F R O R O BE 100 BE 100 NUM NUM 50 50 0 0 –10 –8 –6 –4 –2 0 2 4 6 8 10
002
005
VOS (µV) V
08056-
OS (µV)
08056- Figure 5. Input Offset Voltage Distribution Figure 8. Input Offset Voltage Distribution
10 8 V V SY = 1.8V SY = 5V –40°C ≤ T –40°C ≤ T A ≤ +125°C A ≤ 125°C 8 S S 6 R R LIFIE 6 LIFIE P P M M A A 4 F F R O 4 R O BE BE NUM NUM 2 2 0 0 0 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.10 0 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.10
003 006
TCVOS (µV/°C) TCVOS (µV/°C)
08056- 08056- Figure 6. Input Offset Voltage Drift Distribution with Temperature Figure 9. Input Offset Voltage Drift Distribution with Temperature
15 15 VSY = 1.8V VSY = 5V 10 10 5 5 V) V) (µ 0 (µ 0 OS OS V V DEVICE 1 DEVICE 1 –5 DEVICE 2 –5 DEVICE 2 DEVICE 3 DEVICE 3 DEVICE 4 DEVICE 4 DEVICE 5 DEVICE 5 –10 DEVICE 6 DEVICE 6 DEVICE 7 –10 DEVICE 7 DEVICE 8 DEVICE 8 DEVICE 9 DEVICE 9 DEVICE 10 DEVICE 10 –15 –15 0 0.3 0.6 0.9 1.2 1.5 1.8 0 1 2 3 4 5
004 007
VCM (V) VCM (V)
08056- 08056- Figure 7. Input Offset Voltage vs. Input Common-Mode Voltage Figure 10. Input Offset Voltage vs. Input Common-Mode Voltage Rev. C | Page 8 of 22 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—1.8 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER SEQUENCING ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT VOLTAGE RANGE OUTPUT PHASE REVERSAL OUTLINE DIMENSIONS ORDERING GUIDE
