Datasheet ADA4817-1, ADA4817-2 (Analog Devices) - 9
DescriptionDual, Low Noise, 1 GHz FastFET Op Amplifier
Pages / Page25 / 9 — Data Sheet. ADA4817-1/ADA4817-2. 0.5. 0.4. G = 2, SS. N (. 0.3. G = 2, …
RevisionG
File Format / SizePDF / 632 Kb
Data Sheet. ADA4817-1/ADA4817-2. 0.5. 0.4. G = 2, SS. N (. 0.3. G = 2, LS. B d. 0.2. 0.1. G = 1, SS. OO -L. –0.1. G = 1, LS. D CL. –0.2. OS L
Data Sheet ADA4817-1/ADA4817-2 0.5 0.4 G = 2, SS N ( 0.3 G = 2, LS B d 0.2 0.1 G = 1, SS OO -L –0.1 G = 1, LS D CL –0.2 OS L
Data Sheet ADA4817-1/ADA4817-2 0.5 6 B) 0.4 G = 2, SS d 3 N ( 0.3 AI G = 2, LS ) G B d P 0.2 ( O 0 O IN 0.1 -L G = 1, SS D GA E P S 0 –3 O OO -L –0.1 G = 1, LS D D CL E E –6 IZ –0.2 OS L TA = +25°C, SINGLE AL C T –0.3 A = +25°C, DUAL RM –9 TA = –40°C, SINGLE T NO A = –40°C, DUAL –0.4
36 0
TA = +105°C, SINGLE
6-
T
75
A = +105°C, DUAL –0.5
07 2
–12 100k 1M 10M 100M 1G 10G
01
6-
FREQUENCY (Hz)
75
FREQUENCY (Hz)
07 Figure 14. 0.1 dB Flatness Frequency Response vs. Gain and Output Voltage Figure 17. Small Signal Frequency Response vs. Temperature
–20 –20 –40 –40 –60 –60 Bc) Bc) d d HD2, V ( ( S = 5V N HD2, R N IO L = 100Ω IO HD3, VS = 5V T –80 T –80 R R O HD2, RL = 1kΩ O T T S S DI –100 DI –100 HD3, RL = 100Ω –120 –120 HD2, V HD3, R S = 10V L = 1kΩ HD3, VS = 10V –140 –140
4 3
100k 1M 10M 100M
01
100k 1M 10M 100M
01 6- 6-
FREQUENCY (Hz)
75
FREQUENCY (Hz)
75 07 07 Figure 15. Distortion vs. Frequency for Various Loads, VOUT = 2 V p-p Figure 18. Distortion vs. Frequency for Various Supplies, VOUT = 2 V p-p
–20 –20 fC = 1MHz –40 –40 HD2, VS = 5V –60 –60 Bc) Bc) d HD2, V d ( S = 10V ( N N IO IO T –80 T –80 R R HD2, RL = 100Ω O O T T HD2, R S S L = 1kΩ DI –100 DI –100 HD3, VS = 5V –120 HD3, VS = 10V –120 HD3, RL = 100Ω HD3, RL = 1kΩ –140 –140
6 7
100k 1M 10M 100M
01
0 1 2 3 4 5 6
01 6- 6-
FREQUENCY (Hz)
75
OUTPUT VOLTAGE (V p-p)
75 07 07 Figure 16. Distortion vs. Frequency for Various Supplies, G = 2, VOUT = 2 V p-p Figure 19. Distortion vs. Output Voltage for Various Loads Rev. C | Page 9 of 25 Document Outline FEATURES APPLICATIONS CONNECTION DIAGRAMS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V OPERATION 5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM SAFE POWER DISSIPATION ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS THEORY OF OPERATION CLOSED-LOOP FREQUENCY RESPONSE NONINVERTING CLOSED-LOOP FREQUENCY RESPONSE INVERTING CLOSED-LOOP FREQUENCY RESPONSE WIDEBAND OPERATION DRIVING CAPACITIVE LOADS THERMAL CONSIDERATIONS POWER-DOWN OPERATION CAPACITIVE FEEDBACK HIGHER FREQUENCY ATTENUATION LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS SIGNAL ROUTING POWER SUPPLY BYPASSING GROUNDING EXPOSED PADDLE LEAKAGE CURRENTS INPUT CAPACITANCE INPUT-TO-INPUT/OUTPUT COUPLING APPLICATIONS INFORMATION LOW DISTORTION PINOUT WIDEBAND PHOTODIODE PREAMP HIGH SPEED JFET INPUT INSTRUMENTATION AMPLIFIER ACTIVE LOW-PASS FILTER (LPF) OUTLINE DIMENSIONS ORDERING GUIDE
