Datasheet ADA4311-1 (Analog Devices) - 8
Description | Low Cost, Dual, High Current Output Line Driver with Shutdown |
Pages / Page | 17 / 8 — ADA4311-1. TYPICAL PERFORMANCE CHARACTERISTICS. –40. VOUT = 100mV p-p. … |
File Format / Size | PDF / 304 Kb |
ADA4311-1. TYPICAL PERFORMANCE CHARACTERISTICS. –40. VOUT = 100mV p-p. VOUT = 2V p-p. HD2. HD3. L = 50Ω. RL = 100Ω. PD1, PD0 = 0, 0
ADA4311-1 TYPICAL PERFORMANCE CHARACTERISTICS 9 –40 VOUT = 100mV p-p VOUT = 2V p-p HD2 R HD3 6 L = 50Ω RL = 100Ω PD1, PD0 = 0, 0 –50 G = +5 G = +5 3 c) –60 ) B PD1, PD0 = 1, 0 B d d ( 0 N ( –70 IN IO PD1, PD0 = 0, 1 A –3 RT G –80 PD1, PD0 = 0, 0 D O E T G = +10 S IZ –6 L –90 A C DI M –9 NI O –100 OR G = +20 N –12 HARM –110 –15 –120 –18 –130 1 10 100 1000
05 8 0
0.1 1 10 100
00 0- 0-
FREQUENCY (MHz)
94
FREQUENCY (MHz)
94 06 06 Figure 5. Small Signal Frequency Response for Various Closed-Loop Gains Figure 8. Differential Harmonic Distortion vs. Frequency
9 –60 VOUT = 100mV p-p f = 5MHz 6 RL = 50Ω PD1, PD0 = 0, 0 RL = 100Ω G = +5 G = +5 3 –70 c) 0 B (d HD2 –80 –3 ) PD1, PD0 = 0, 1 TION B d –6 ( OR T IN –90 –9 IS GA D –12 PD1, PD0 = 1, 0 IC HD3 ON –100 –15 M R A –18 H –110 –21 –24 –120 1 10 100 1000
06 21 0 0
0.1 1 10
0- 0-
FREQUENCY (MHz)
94 694
OUTPUT VOLTAGE (V p-p)
06 0 Figure 6. Small Signal Frequency Response for Various Modes Figure 9. Differential Harmonic Distortion vs. Output Voltage
0.20 –40 G = +5 VOUT = 2V p-p RL = 50Ω f = 5MHz 0.15 10ns/DIV –50 G = +5 0.10 Bc) d ( –60 N ) 0.05 IO V T ( R –70 T U O 0 T HD2 TP S DI –80 OU –0.05 IC N O –90 –0.10 ARM HD3 H –0.15 –100
0 01 0-
–0.20
94
–110
06 22 0
10 100 1000
0- 94
LOAD RESISTANCE (Ω)
06 Figure 7. Small Signal Transient Response Figure 10. Differential Harmonic Distortion vs. Load Resistance Rev. 0 | Page 7 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION TYPICAL APPLICATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION INFORMATION FEEDBACK RESISTOR SELECTION POWER CONTROL MODES OF OPERATION EXPOSED THERMAL PAD CONNECTIONS POWERLINE APPLICATION BOARD LAYOUT POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
