Datasheet AD8538, AD8539 (Analog Devices) - 7
DescriptionLow Power, Precision, Auto-Zero Op Amp
Pages / Page24 / 7 — Data Sheet. AD8538/AD8539. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. …
File Format / SizePDF / 810 Kb
Data Sheet. AD8538/AD8539. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 5. Parameter Rating
Data Sheet AD8538/AD8539 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 5 Parameter Rating
THERMAL RESISTANCE Table 5.
θJA is specified for the worst-case conditions, that is, a device
Parameter Rating
soldered in a circuit board for surface-mount packages. Supply Voltage +6 V
Table 6. Thermal Characteristics
Input Voltage VSS − 0.3 V to VDD + 0.3 V
Package Type θ
Differential Input Voltage ±6 V
JA θJC Unit
Output Short-Circuit Duration to GND Observe derating curve 5-Lead TSOT-23 (UJ-5) 207 61 °C/W Storage Temperature Range –65°C to +150°C 8-Lead SOIC_N (R-8) 125 43 °C/W Lead Temperature (Soldering, 60 sec) 300°C 8-Lead MSOP (RM-8) 145 45 °C/W Operating Temperature Range –40°C to +125°C Junction Temperature Range −65°C to +150°C
ESD CAUTION
Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Absolute maximum ratings apply at 25°C, unless otherwise noted. Rev. B | Page 7 of 24 Document Outline Features Applications General Description Pin Configurations Revision History Specifications AD8538 Electrical Specifications AD8539 Electrical Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics AD8538 Characteristics AD8539 Characteristics Outline Dimensions Ordering Guide Automotive Products
