Datasheet ADA4853-1, ADA4853-2, ADA4853-3 (Analog Devices) - 9
DescriptionLow Power, Rail-to-Rail Output, Video Op Amps with Ultralow Power
Pages / Page20 / 9 — Data Sheet. ADA4853-1/ADA4853-2/ADA4853-3. +85°C. G = –1. S = 5V. L = …
RevisionG
File Format / SizePDF / 540 Kb
Data Sheet. ADA4853-1/ADA4853-2/ADA4853-3. +85°C. G = –1. S = 5V. L = 150Ω. +25°C. VOUT = 0.1V p-p. G = +1. G = +2. G = +10. –40°C. G P. D E. SE O
Data Sheet ADA4853-1/ADA4853-2/ADA4853-3 +85°C G = –1 S = 5V L = 150Ω +25°C VOUT = 0.1V p-p G = +1 G = +2 G = +10 –40°C G P D E SE O
Data Sheet ADA4853-1/ADA4853-2/ADA4853-3 1 4 V +85°C G = –1 S = 5V ) R 3 L = 150Ω B +25°C 0 VOUT = 0.1V p-p (d G = +1 IN G = +2 2 A ) G G = +10 –1 B P (d 1 IN OO A -L 0 –2 –40°C D G P SE –1 O OO L –3 -L C D –2 D E SE O –4 –3 LIZ L A C M –4 R O –5 V N S = 5V RL = 150Ω –5 VOUT = 2V p-p –6 –6
011
0.1 1 10 100 200
014
0.1 1 10 100 200 FREQUENCY (MHz) FREQUENCY (MHz)
05884- 05884- Figure 13. Large Signal Frequency Response for Various Gains Figure 16. Small Signal Frequency Response for Various Temperatures
7 250 VS = 5V RL = 150Ω 6 G = +2 200 ) RL= 75Ω B R NEGATIVE SLEW RATE 5 L= 1kΩ (d s) IN RL= 150Ω A 150 G (V 4 P E OO -L RAT 3 POSITIVE SLEW RATE D W 100 E SE L O S L 2 C 50 1 VS = 5V VOUT = 2V p-p G = +2 0 0
012 015
0.1 1 10 100 200 0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 FREQUENCY (MHz) OUTPUT VOLTAGE STEP (V)
05884- 05884- Figure 14. Large Signal Frequency Response for Various Loads Figure 17. Slew Rate vs. Output Voltage
5 140 0 VS = 3V +85°C VS = 5V 4 RL = 150Ω R +25°C L = 150Ω V 120 –30 OUT = 0.1V p-p 3 G = +1 ) 2 ) 100 –60 dB rees) ( dB PHASE IN 1 ( Deg IN 80 –90 ( E GA 0 –40°C GA 60 –120 HAS –1 P -LOOP P GAIN D -LOOP O E –2 N 40 –150 O E L LOS OP N- C –3 E 20 –180 P O –4 0 –210 –5 –6
013
–20 –240 0.1 1 10 100 200 100 1k 10k 100k 1M 10M 100M
029
FREQUENCY (MHz)
05884-
FREQUENCY (Hz)
05884- Figure 15. Small Signal Frequency Response for Various Temperatures Figure 18. Open-Loop Gain and Phase vs. Frequency Rev. G | Page 9 of 20 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH 3 V SUPPLY SPECIFICATIONS WITH 5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM CONSIDERATIONS OVERLOAD BEHAVIOR AND RECOVERY Input APPLICATIONS INFORMATION SINGLE-SUPPLY VIDEO AMPLIFIER POWER SUPPLY BYPASSING LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
