ADA4310-1Data SheetPIN CONFIGURATIONS AND FUNCTION DESCRIPTIONSAT BCUTSONI+VOU16151413NIC 112 NICADA4310-1−IN A 211 −IN B+VS 110 OUT B+IN A 310 +IN BNIC 29–IN BGND 49PD1ADA4310-1OUT A38+IN B–IN A47PD15678+IN A56PD0CCSNINID0–VPNOTESNOTES1. NIC = NO INTERNAL CONNECTION.1. THE EXPOSED PAD MUST BE CONNECTED 101 002 TO GROUND (ELECTRICAL CONNECTION REQUIRED).2. THE EXPOSED PAD MUST BE2. NIC = NO INTERNAL CONNECTION.CONNECTED TO GND. 06027- 06027- Figure 5. 10-Lead MSOP Pin Configuration Figure 6. 16-Lead LFCSP Pin Configuration Table 4. 10-Lead MSOP Pin Function DescriptionTable 5. 16-Lead LFCSP Pin Function DescriptionPin No.MnemonicDescriptionPin No.MnemonicDescription 1 +VS Positive Power Supply Input 1, 5, 6, 12, 15 NIC No Internal Connection 2 NIC No Internal Connection 2 −IN A Amplifier A Inverting Input 3 OUT A Amplifier A Output 3 +IN A Amplifier A Noninverting Input 4 −IN A Amplifier A Inverting Input 4 GND Ground 5 +IN A Amplifier A Noninverting Input 7 −VS Negative Power Supply Input 6 PD0 Power Dissipation Control 8 PD0 Power Dissipation Control 7 PD1 Power Dissipation Control 9 PD1 Power Dissipation Control 8 +IN B Amplifier B Noninverting Input 10 +IN B Amplifier B Noninverting Input 9 −IN B Amplifier B Inverting Input 11 −IN B Amplifier B Inverting Input 10 OUT B Amplifier B Output 13 OUT B Amplifier B Output 11 (Exposed GND Ground (Electrical Connection 14 +VS Positive Power Supply Input Paddle) Required) 16 OUT A Amplifier A Output 17 (Exposed GND Ground Paddle) Rev. B | Page 6 of 14 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION INFORMATION FEEDBACK RESISTOR SELECTION POWER CONTROL MODES OF OPERATION EXPOSED THERMAL PAD CONNECTIONS POWER LINE APPLICATION BOARD LAYOUT POWER SUPPLY BYPASSING OUTLINE DIMENSIONS ORDERING GUIDE
