Datasheet ADA4851-1, ADA4851-2, ADA4851-4 (Analog Devices) - 6
DescriptionLow Cost, High Speed, Rail-to-Rail, Output Op Amp (Dual)
Pages / Page24 / 6 — ADA4851-1/ADA4851-2/ADA4851-4. SPECIFICATIONS WITH +5 V SUPPLY. Table 2. …
RevisionJ
File Format / SizePDF / 412 Kb
ADA4851-1/ADA4851-2/ADA4851-4. SPECIFICATIONS WITH +5 V SUPPLY. Table 2. Parameter Conditions. Min. Typ. Max. Unit
ADA4851-1/ADA4851-2/ADA4851-4 SPECIFICATIONS WITH +5 V SUPPLY Table 2 Parameter Conditions Min Typ Max Unit
TA = 25°C, RF = 0 Ω for G = +1, RF = 1 kΩ for G > +1, RL = 1 kΩ, unless otherwise noted.
Table 2. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VOUT = 0.1 V p-p 96 125 MHz ADA4851-1W/2W/4W only: TMIN to TMAX 90 MHz G = +1, VOUT = 0.5 V p-p 72 96 MHz ADA4851-1W/2W/4W only: TMIN to TMAX 64 MHz G = +2, VOUT = 1.4 V p-p, RL = 150 Ω 35 MHz Bandwidth for 0.1 dB Flatness G = +2, VOUT = 1.4 V p-p, RL = 150 Ω 11 MHz Slew Rate G = +2, VOUT = 2 V step 200 V/μs Settling Time to 0.1% G = +2, VOUT = 2 V step, RL = 150 Ω 55 ns NOISE/DISTORTION PERFORMANCE Harmonic Distortion, HD2/HD3 fC = 1 MHz, VOUT = 2 V p-p, G = +1 −80/−100 dBc Input Voltage Noise f = 100 kHz 10 nV/√Hz Input Current Noise f = 100 kHz 2.5 pA/√Hz Differential Gain G = +2, NTSC, RL = 150 Ω, VOUT = 2 V p-p 0.08 % Differential Phase G = +2, NTSC, RL = 150 Ω, VOUT = 2 V p-p 0.11 Degrees Crosstalk (RTI)—ADA4851-2/ADA4851-4 f = 5 MHz, G = +2, VOUT = 2.0 V p-p −70/−60 dB DC PERFORMANCE Input Offset Voltage 0.6 3.4 mV ADA4851-1W/2W/4W only: TMIN to TMAX 7.4 mV Input Offset Voltage Drift 4 μV/°C Input Bias Current 2.2 3.9 μA ADA4851-1W/2W/4W only: TMIN to TMAX 4.9 μA Input Bias Current Drift 6 nA/°C Input Bias Offset Current 20 nA Open-Loop Gain VOUT = 1 V to 4 V 97 107 dB ADA4851-1W/2W/4W only: TMIN to TMAX 90 dB INPUT CHARACTERISTICS Input Resistance Differential/common-mode 0.5/5.0 MΩ Input Capacitance 1.2 pF Input Common-Mode Voltage Range −0.2 to +2.8 V Input Overdrive Recovery Time (Rise/Fall) VIN = +5.5 V, −0.5 V, G = +1 50/45 ns Common-Mode Rejection Ratio VCM = 0 V to 2 V −86 −105 dB ADA4851-1W/2W/4W only: TMIN to TMAX −80 dB POWER-DOWN—ADA4851-1 ONLY Power-Down Input Voltage Power-down <1.1 V Power-up >1.6 V Turn-Off Time 0.7 μs Turn-On Time 50 ns Power-Down Bias Current Enabled POWER DOWN = 5 V 33 40 μA ADA4851-1W only: TMIN to TMAX 40 μA Power-Down POWER DOWN = 0 V −22 −30 μA ADA4851-1W only: TMIN to TMAX −30 μA Rev. J | Page 6 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH +3 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY SPECIFICATIONS WITH ±5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM CONSIDERATIONS OVERLOAD BEHAVIOR AND RECOVERY Input Output SINGLE-SUPPLY VIDEO AMPLIFIER VIDEO RECONSTRUCTION FILTER OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
