Datasheet ADA4851-1, ADA4851-2, ADA4851-4 (Analog Devices) - 9
DescriptionLow Cost, High Speed, Rail-to-Rail, Output Op Amp (Dual)
Pages / Page24 / 9 — ADA4851-1/ADA4851-2/ADA4851-4. Parameter Conditions. Min. Typ. Max. Unit
RevisionJ
File Format / SizePDF / 412 Kb
ADA4851-1/ADA4851-2/ADA4851-4 Parameter Conditions Min Typ Max Unit
OUTPUT CHARACTERISTICS Output Overdrive Recovery Time (Rise/Fall) VIN = ±1.2 V, G = +5 80/50 ns Output Voltage Swing −4.87 to +4.88 −4.92 to +4.92 V ADA4851-1W/2W/4W only: TMIN to TMAX −4.85 to +4.85 V Linear Output Current 1% THD with 1 MHz, VOUT = 2 V p-p 83 mA Short-Circuit Current Sinking/sourcing 125/110 mA POWER SUPPLY Operating Range 2.7 12 V Quiescent Current per Amplifier 2.9 3.2 mA ADA4851-1W/2W/4W only: TMIN to TMAX 3.2 mA Quiescent Current (Power-Down) POWER DOWN = low 0.2 0.325 mA ADA4851-1W only: TMIN to TMAX 0.325 mA Positive Power Supply Rejection +VS = +5 V to +6 V, −VS = −5 V −82 −101 dB ADA4851-1W/2W/4W only: TMIN to TMAX −82 dB Negative Power Supply Rejection +VS = +5 V, −VS = −5 V to −6 V −81 −102 dB ADA4851-1W/2W/4W only: TMIN to TMAX −81 dB Rev. J | Page 9 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATIONS GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH +3 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY SPECIFICATIONS WITH ±5 V SUPPLY ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Maximum Power Dissipation ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION HEADROOM CONSIDERATIONS OVERLOAD BEHAVIOR AND RECOVERY Input Output SINGLE-SUPPLY VIDEO AMPLIFIER VIDEO RECONSTRUCTION FILTER OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
