Datasheet AD8641, AD8642, AD8643 (Analog Devices)
DescriptionLow Power, Rail-to-Rail Output, Precision JFET Amplifiers
Pages / Page15 / 1 — Low Power, Rail-to-Rail Output, Precision. JFET Amplifiers. Data Sheet. …
RevisionF
File Format / SizePDF / 323 Kb
Low Power, Rail-to-Rail Output, Precision. JFET Amplifiers. Data Sheet. AD8641. /AD8642/. AD8643. FEATURES. PIN CONFIGURATIONS
Datasheet AD8641, AD8642, AD8643 Analog Devices, Revision: F
Low Power, Rail-to-Rail Output, Precision JFET Amplifiers Data Sheet AD8641 /AD8642/ AD8643 FEATURES PIN CONFIGURATIONS Low supply current: 250 μA max OUT 1 5 VCC Very low input bias current: 1 pA max AD8641 Low offset voltage: 750 μV max VEE 2 TOP VIEW (Not to Scale) Single-supply operation: 5 V to 26 V +IN 3 4 –IN Dual-supply operation: ±2.5 V to ±13 V
05072-101
Rail-to-rail output
Figure 1. 5-Lead SC70 (KS-5)
Unity-gain stable NIC 1 8 NIC No phase reversal –IN 2 AD8641 7 VCC SC70 package +IN 3 TOP VIEW 6 OUT (Not to Scale) VEE 4 5 NIC APPLICATIONS
02 1 2- 07
NIC = NO INTERNAL CONNECTION. Line-/battery-powered instruments
05 Figure 2. 8-Lead SOIC (R-8)
Photodiode amplifiers Precision current sensing OUT A 1 8 V+ Medical instrumentation –IN A 2 AD8642 7 OUT B Industrial controls +IN A 3 TOP VIEW 6 –IN B
05
(Not to Scale)
1 2-
Precision filters V– 4 5 +IN B
07 05
Portable audio
Figure 3. 8-Lead SOIC (R-8)
ATE OUT A 1 8 V+ GENERAL DESCRIPTION –IN A AD8642 2 7 OUT B TOP VIEW +IN A 3 6 –IN B
The AD8641/AD8642/AD8643 are low power, precision JFET
(Not to Scale) V– 4 5 +IN B
input amplifiers featuring extremely low input bias current and 05072-064 Figure 4. 8-Lead MSOP (RM-8) rail-to-rail output. The ability to swing nearly rail-to-rail at the input and rail-to-rail at the output enables designers to buffer
OUT A 1 14 OUT D
complementary metal-oxide semiconductor digital-to-analog
–IN A 2 13 –IN D
converters (CMOS DACs), ASICs, and other wide output swing
+IN A 3 12 +IN D AD8643
devices in single-supply systems. The outputs remain stable
V+ 4 TOP VIEW 11 V– (Not to Scale)
with capacitive loads of more than 500 pF.
+IN B 5 10 +IN C –IN B 6 9 –IN C
The AD8641/AD8642/AD8643 are suitable for applications
OUT B 7 8 OUT C
utilizing multichannel boards that require low power to manage 05072-103 heat. Other applications include photodiodes, ATE reference Figure 5. 14-Lead SOIC (R-14) level drivers, battery management, and industrial controls.
A PIN 1 T T D C C INDICATOR
The AD8641/AD8642/AD8643 are fully specified over the
NI OU OU NI 6 5 4 3 1 1 1 1
extended industrial temperature range of −40°C to +125°C. The AD8641 is available in 5-lead SC70 and 8-lead SOIC lead-free
–IN A 1 12 –IN D
packages. The AD8642 is available in 8-lead MSOP and 8-lead
+IN A 2 11 +IN D AD8643
SOIC lead-free packages. The AD8643 is available in 14-lead
V+ 3 TOP VIEW 10 V–
SOIC and 16-lead, 3 mm × 3 mm, LFCSP lead-free packages.
+IN B 4 9 +IN C 5 6 7 8 N B T B T C N C –I –I OU OU NOTES
-104
1. NIC = NO INTERNAL CONNECTION.
72
2. EXPOSED PAD SHOULD BE CONNECTED TO V+.
050 Figure 6. 16-Lead LFCSP (CP-16-27) (Not Drawn to Scale)
Rev. F Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2004–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
