Datasheet ADD8710 (Analog Devices) - 6 Manufacturer Analog Devices Description 10-Channel Gamma Buffer with VCOM Driver Pages / Page 13 / 6 — ADD8710. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 0.7. T = 25°C V. 700. … Revision B File Format / Size PDF / 287 Kb Document Language English
ADD8710. TYPICAL PERFORMANCE CHARACTERISTICS. 800. 0.7. T = 25°C V. 700. S = 4.5V TO 16V. 0.6. 600. R (. 0.5. E F. 500. UNI F. /BUF. 0.4. 400. R O BE. 0.3
Model Line for this Datasheet Text Version of Document ADD8710 TYPICAL PERFORMANCE CHARACTERISTICS 800 0.7 T = 25°C V 700 S = 4.5V TO 16V 0.6 A) 600 m S R ( 0.5 T E F 500 UNI F /BUF 0.4 400 NT R O BE 0.3 300 NUM CURRE LY 0.2 200 P P U S 100 0.1 0 0 –8 –7 –6 –5 –4 –3 –2 –1 0 1 2 3 4 5 6 7 8 003 006 9-0 2 4 6 8 10 12 14 16 18 89-VOS (mV) 488 0SUPPLY VOLTAGE (V) 48 0 Figure 3. Input Offset Voltage Distribution Figure 6. Supply Current/Buffer vs. Supply Voltage300 1.0 0.9 250 A) 0.8 m R ( S 0.7 200 E T F 0.6 UNI F /BUF 150 NT 0.5 R O BE 0.4 100 CURRE NUM LY 0.3 P P U 0.2 50 S 0.1 0 3 0 0046 9 00712 15 18 21 24 27 30 33 36 39 4 42 45 48 51 5 57 60 63 66 69 72 75 9-78 –40 –20 0 20 40 60 80 100 120 89-TCVOS (µV/°C) 488 48 0TEMPERATURE (°C) 0 Figure 4. Input Offset Voltage Drift Distribution Figure 7. Supply Current/Buffer vs. Temperature5 V1 V7 V1 V7 V8 600 V2 V8 4 V2 V3 V3 V9 V9 V10 V4 V10 V) V4 3 A) V5 V m V5 VCOM n 400 COM ( V6 E ( V6 G 2 NT LTA O 1 RRE 200 T V CU E S 0 IA FFS B 0 UT T O –1 U P INP IN –2 –200 –3 8–400 05–4 -00 0120 –40 –20 0 20 40 60 80 100 9-120 –40 –20 0 20 40 60 80 100 TEMPERATURE (°C) 889TEMPERATURE (°C) 88 04 04 Figure 5. Input Offset Voltage vs. Temperature Figure 8. Input Bias Current vs. Temperature Rev. B | Page 5 of 12 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
