Datasheet AD8099 (Analog Devices) - 4
DescriptionUltralow Distortion, High Speed 0.95nV/√Hz Voltage Noise Op Amp
Pages / Page28 / 4 — AD8099. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/2016—Rev. D to …
RevisionE
File Format / SizePDF / 667 Kb
AD8099. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 7/2016—Rev. D to Rev. E. 6/2004—Rev. A to Rev. B. 1/2004—Rev. 0 to Rev. A
AD8099 Data Sheet TABLE OF CONTENTS REVISION HISTORY 7/2016—Rev D to Rev E 6/2004—Rev A to Rev B 1/2004—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 4 link to page 5 link to page 5 link to page 6 link to page 7 link to page 7 link to page 7 link to page 8 link to page 17 link to page 18 link to page 18 link to page 18 link to page 19 link to page 19 link to page 21 link to page 23 link to page 23 link to page 23 link to page 24 link to page 25 link to page 25 link to page 26 link to page 26
Features .. 1 Using the AD8099 .. 16 Applications ... 1 Circuit Components .. 16 General Description ... 1 Recommended Values ... 17 Connection Diagrams .. 1 Circuit Configurations .. 17 Revision History ... 2 Performance vs. Component Values .. 19 Specifications ... 3 Total Output Noise Calculations and Design ... 21 Specifications with ±5 V Supply ... 3 Input Bias Current and DC Offset ... 21 Specifications with +5 V Supply ... 4 DISABLE Pin and Input Bias Cancel ation ... 21 Absolute Maximum Ratings .. 5 16-Bit ADC Driver ... 22 Maximum Power Dissipation ... 5 Circuit Considerations .. 23 ESD Caution .. 5 Design Tools and Technical Support ... 23 Typical Performance Characteristics ... 6 Outline Dimensions ... 24 Theory of Operation .. 15 Ordering Guide .. 24 Applications Information .. 16
REVISION HISTORY 7/2016—Rev. D to Rev. E 6/2004—Rev. A to Rev. B
Changed CP-8-2 to CP-8-13 .. Throughout Change to General Description Section ... 1 Changes to Figure 1 and Figure 2 ... 1 Changes to Maximum Power Dissipation Section .. 5 Changes to Figure 67 .. 19 Changes to Applications Section ... 16 Added Figure 68 to Figure 70; Renumbered Sequentially .. 19 Changes to Table 7 .. 24 Changes to Figure 71 .. 20 Changes to Ordering Guide .. 26 Added Figure 72 and Figure 73... 20 Changes to PCB Layout Section ... 23
Updated Outline Dimensions ... 24 Inserted Figure 3 .. 1 Changes to Ordering Guide ... 24 Changes to Specifications Section ... 3 Inserted Figure 22 to Figure 34 .. 8
8/2013—Rev. C to Rev. D
Inserted Figure 51 to Figure 55 ... 14 Changes to Figure 42 Caption ... 12 Changes to Theory of Operation Section.. 16 Changes to Figure 49 .. 13 Changes to Circuit Components Section .. 17 Changes to Ordering Guide .. 25 Changes to Table 4 .. 18 Changes to Figure 60 .. 18
1/2013—Rev. B to Rev. C
Changes to Total Output Noise Calculations and Added EPAD Note to Figure 1 and Figure 2 ... 1 Design Section .. 21 Changes to PCB Layout Section and Design Tools and Changes to Figure 60 .. 22 Technical Support Section ... 23 Changes to Figure 62 .. 23 Deleted Figure 72, Figure 73, Evaluation Boards Section, Changes to 16-Bit ADC Driver Section .. 23 and Table 7 ... 24 Changes to Table 6 .. 23 Updated Outline Dimensions ... 25 Additions to PCB Layout Section ... 23 Changes to Ordering Guide .. 26
11/2003—Revision 0: Initial Version
Rev. E | Page 2 of 26 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY SPECIFICATIONS WITH +5 V SUPPLY ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION USING THE AD8099 CIRCUIT COMPONENTS RECOMMENDED VALUES CIRCUIT CONFIGURATIONS PERFORMANCE vs. COMPONENT VALUES TOTAL OUTPUT NOISE CALCULATIONS AND DESIGN INPUT BIAS CURRENT AND DC OFFSET PIN AND INPUT BIAS CANCELLATION 16-BIT ADC DRIVER CIRCUIT CONSIDERATIONS PCB Layout Parasitics Grounding Power Supply Bypassing Component Selection DESIGN TOOLS AND TECHNICAL SUPPORT OUTLINE DIMENSIONS ORDERING GUIDE
