Datasheet AD8029, AD8030, AD8040 (Analog Devices) - 3
DescriptionLow Power, High Speed Rail-to-Rail Input/Output Amplifier
Pages / Page24 / 3 — Data Sheet. AD8029/AD8030/AD8040. SPECIFICATIONS SPECIFICATIONS WITH ±5 V …
RevisionB
File Format / SizePDF / 454 Kb
Data Sheet. AD8029/AD8030/AD8040. SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY
Data Sheet AD8029/AD8030/AD8040 SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY
link to page 4
Data Sheet AD8029/AD8030/AD8040 SPECIFICATIONS SPECIFICATIONS WITH ±5 V SUPPLY Table 1. VS = ±5 V @ TA = 25°C, G = +1, RL = 1 kΩ to ground, unless otherwise noted. All specifications are per amplifier. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE –3 dB Bandwidth G = +1, VO = 0.1 V p-p 80 125 MHz AD8040W only: TMIN to TMAX 80 MHz G = +1, VO = 2 V p-p 14 19 MHz AD8040W only: TMIN to TMAX 9 MHz Bandwidth for 0.1 dB Flatness G = +2, VO = 0.1 V p-p 6 MHz Slew Rate G = +1, VO = 2 V Step 62 V/μs G = –1, VO = 2 V Step 63 V/μs Settling Time to 0.1% G = +2, VO = 2 V Step 80 ns NOISE/DISTORTION PERFORMANCE Spurious Free Dynamic Range (SFDR) fC = 1 MHz, VO = 2 V p-p –74 dBc fC = 5 MHz, VO = 2 V p-p –56 dBc Input Voltage Noise f = 100 kHz 16.5 nV/√Hz Input Current Noise f = 100 kHz 1.1 pA/√Hz Crosstalk (AD8030/AD8040) f = 5 MHz, VIN = 2 V p-p –79 dB DC PERFORMANCE Input Offset Voltage PNP Active, VCM = 0 V 1.6 5 mV AD8040W only: TMIN to TMAX 9.5 mV NPN Active, VCM = 4.5 V 2 6 mV AD8040W only: TMIN to TMAX 9.5 mV Input Offset Voltage Drift TMIN to TMAX 30 μV/°C Input Bias Current1 NPN Active, VCM = 4.5 V 0.7 1.3 μA TMIN to TMAX 1 μA AD8040W only: TMIN to TMAX 1.3 μA PNP Active, VCM = 0 V –1.7 –2.8 μA TMIN to TMAX 2 μA AD8040W only: TMIN to TMAX –2.8 μA Input Offset Current ±0.1 ±0.9 μA AD8040W only: TMIN to TMAX ±0.9 μA Open-Loop Gain Vo = ±4.0 V 65 74 dB AD8040W only: TMIN to TMAX 62 dB INPUT CHARACTERISTICS Input Resistance 6 MΩ Input Capacitance 2 pF Input Common-Mode Voltage Range –5.2 to +5.2 V Common-Mode Rejection Ratio VCM = –4.5 V to +3 V, RL = 10 kΩ 80 90 dB AD8040W only: TMIN to TMAX 80 dB DISABLE PIN (AD8029) DISABLE Low Voltage –VS + 0.8 V DISABLE Low Current –6.5 μA DISABLE High Voltage –VS + 1.2 V DISABLE High Current 0.2 μA Turn-Off Time 50% of DISABLE to <10% of Final VO, 150 ns VIN = –1 V, G = –1 Turn-On Time 50% of DISABLE to <10% of Final VO, 85 ns VIN = –1 V, G = –1 OUTPUT CHARACTERISTICS Output Overdrive Recovery Time (Rising/Falling Edge) VIN = +6 V to –6 V, G = –1 55/45 ns Output Voltage Swing RL = 1 kΩ –VS + 0.22 +VS – 0.22 V AD8040W only: TMIN to TMAX –VS + 0.22 +VS – 0.22 V RL = 10 kΩ –VS + 0.05 +VS – 0.05 V AD8040W only: TMIN to TMAX –VS + 0.05 +VS – 0.05 V Rev. B | Page 3 of 24 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications Specifications with ±5 V Supply Specifications with +5 V Supply Specifications with +3 V Supply Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Output Stage Applications Wideband Operation Output Loading Sensitivity Disable Pin Circuit Considerations PCB Layout Grounding Power Supply Bypassing Design Tools and Technical Support Outline Dimensions Ordering Guide
