Datasheet AD8029, AD8030, AD8040 (Analog Devices) - 10
DescriptionLow Power, High Speed Rail-to-Rail Input/Output Amplifier
Pages / Page24 / 10 — AD8029/AD8030/AD8040. Data Sheet. –35. –40. G = +1. OUT = 2V p-p. –45. …
RevisionB
File Format / SizePDF / 454 Kb
AD8029/AD8030/AD8040. Data Sheet. –35. –40. G = +1. OUT = 2V p-p. –45. SECOND HARMONIC: SOLID LINE. L = 1k. –50
AD8029/AD8030/AD8040 Data Sheet –35 –40 G = +1 OUT = 2V p-p –45 SECOND HARMONIC: SOLID LINE L = 1k –50
AD8029/AD8030/AD8040 Data Sheet –35 –40 G = +1 G = +1 V V OUT = 2V p-p OUT = 2V p-p –45 R SECOND HARMONIC: SOLID LINE L = 1k
–50 SECOND HARMONIC: SOLID LINE THIRD HARMONIC: DASHED LINE THIRD HARMONIC: DASHED LINE –55 –60 –65 –70 V RL = 1k
S = +3V –75 –80 –85 –90 VS = +5V R V L = 5k
HARMONIC DISTORTION (dBc) S =
5V HARMONIC DISTORTION (dBc) –95 –100 RL = 2k
–105 –110 0.01 0.1 1 10 0.01 0.1 1 10 FREQUENCY (MHz) FREQUENCY (MHz)
03679-0-016 03679-0-075 Figure 19. Harmonic Distortion vs. Frequency and Supply Voltage Figure 22. Harmonic Distortion vs. Frequency and Load
–40 –40 G = +2 G = +1 FREQ = 1MHz VOUT = 2V p-p –45 RF = 1k
FREQ = 1MHz –50 VS = +5V VS = +10V –50 VS = +3V VS = +3V VS = +5V –60 –55 –60 –70 –65 –80 –70 HARMONIC DISTORTION (dBc) HARMONIC DISTORTION (dBc) –90 –75 SECOND HARMONIC: SOLID LINE SECOND HARMONIC: SOLID LINE THIRD HARMONIC: DASHED LINE THIRD HARMONIC: DASHED LINE –80 –100 0.5 1.5 2.5 3.5 4.5 5.5 6.5 7.5 8.5 9.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 OUTPUT AMPLITUDE (V p-p)
03679-A-015
INPUT COMMON-MODE VOLTAGE (V)
03679-0-020 Figure 20. Harmonic Distortion vs. Output Amplitude Figure 23. Harmonic Distortion vs. Input Common Mode Voltage
–30 1000 100 VS = +5V VOUT = 2.0V p-p –40 RL = 1k
RF = 1k
–50 G = +2 100 10 –60 G = –1 –70 VOLTAGE NOISE –80 10 1 CURRENT NOISE –90 VOLTAGE NOISE (nV/ Hz) CURRENT NOISE (pA/ Hz) HARMONIC DISTORTION (dBc) G = +1 –100 SECOND HARMONIC: SOLID LINE THIRD HARMONIC: DASHED LINE –110 1 0.1 0.01 0.1 1 10 10 100 1k 10k 100k 1M 10M FREQUENCY (MHz) FREQUENCY (Hz)
03679-0-069 03679-A-016 Figure 21. Harmonic Distortion vs. Frequency and Gain Figure 24. Voltage and Current Noise vs. Frequency Rev. B | Page 10 of 24 Document Outline Features Applications Connection Diagrams General Description Table of Contents Revision History Specifications Specifications with ±5 V Supply Specifications with +5 V Supply Specifications with +3 V Supply Absolute Maximum Ratings Maximum Power Dissipation Output Short Circuit ESD Caution Typical Performance Characteristics Theory of Operation Input Stage Output Stage Applications Wideband Operation Output Loading Sensitivity Disable Pin Circuit Considerations PCB Layout Grounding Power Supply Bypassing Design Tools and Technical Support Outline Dimensions Ordering Guide
