Datasheet AD8605, AD8606, AD8608 (Analog Devices) - 10
DescriptionLow Noise, CMOS, Rail-to-Rail, Input/Output Precision Quad Op Amp
Pages / Page24 / 10 — AD8605/AD8606/AD8608. Data Sheet. 5.00. VOH @ 1mA LOAD. 4.95. VS = 5V. …
RevisionO
File Format / SizePDF / 850 Kb
AD8605/AD8606/AD8608. Data Sheet. 5.00. VOH @ 1mA LOAD. 4.95. VS = 5V. 4.90. E (V). VIN = 4.9V p-p. G A. TA = 25°C. G (. L = 2kΩ. 4.85. WIN. AV = 1
AD8605/AD8606/AD8608 Data Sheet 5.00 VOH @ 1mA LOAD 4.95 VS = 5V 4.90 E (V) VIN = 4.9V p-p G A TA = 25°C G ( L = 2kΩ 4.85 WIN AV = 1
AD8606
AD8605/AD8606/AD8608 Data Sheet 5.00 6 VOH @ 1mA LOAD 4.95 5 VS = 5V p) VS = 5V 4.90 p- 4 E (V) V VIN = 4.9V p-p G A TA = 25°C T G ( L R O L = 2kΩ 4.85 WIN 3 AV = 1 T V T S U U TP 4.80 TP 2 OU OU VOH @ 10mA LOAD 4.75 1
013 016
4.70
02731-
0
02731-
–40 –25 –10 5 20 35 50 65 80 95 110 125 1k 10k 100k 1M 10M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 13. Output Voltage Swing High vs. Temperature Figure 16. Closed-Loop Output Voltage Swing (FPBW)
0.25 100 VS = 5V VS = 5V V 90 OL @ 10mA LOAD 0.20 80 ) (Ω 70 E (V) AV = 100 G 0.15 60 A LT O 50 PEDANCE T V A A V = 10 V = 1 IM U 0.10 40 TP PUT OU UT 30 O 0.05 20 VOL @ 1mA LOAD
014
10
017
0
02731-
0
02731-
–40 –25 –10 5 20 35 50 65 80 95 110 125 1k 10k 100k 1M 10M 100M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 14. Output Voltage Swing Low vs. Temperature Figure 17. Output Impedance vs. Frequency
100 225 120 V V S = ±2.5V S = 5V 80 R 180 110 L = 2kΩ CL = 20pF 60 135 Φ 100 M = 64° PHASE 40 90 90 20 45 80 B) rees) B) d d N ( 0 0 Deg 70 ( AI RR ( GAIN E G –20 –45 CM 60 HAS P –40 –90 50 –60 –135 40 –80 –180 30
015 018
–100 –225
02731-
20
02731-
10k 100k 1M 10M 40M 1k 10k 100k 1M 10M FREQUENCY (Hz) FREQUENCY (Hz)
Figure 15. Open-Loop Gain and Phase vs. Frequency Figure 18. Common-Mode Rejection Ratio (CMRR) vs. Frequency Rev. N | Page 10 of 24 Document Outline Features Applications General Description Pin Configurations Revision History 5 V Electrical Specifications 2.7 V Electrical Specifications Absolute Maximum Ratings ESD Caution Typical Performance Characteristics Applications Information Output Phase Reversal Maximum Power Dissipation Input Overvoltage Protection THD + Noise Total Noise Including Source Resistors Channel Separation Capacitive Load Drive Light Sensitivity WLCSP Assembly Considerations I-V Conversion Applications Photodiode Preamplifier Applications Audio and PDA Applications Instrumentation Amplifiers DAC Conversion Outline Dimensions Ordering Guide
