Datasheet AD8038, AD8039 (Analog Devices)
Description | Low Power, 350 MHz Voltage Feedback Amplifiers |
Pages / Page | 16 / 1 — Low Power, 350 MHz. Voltage Feedback Amplifiers. AD8038/AD8039. FEATURES. … |
Revision | G |
File Format / Size | PDF / 305 Kb |
Low Power, 350 MHz. Voltage Feedback Amplifiers. AD8038/AD8039. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Low Power, 350 MHz Voltage Feedback Amplifiers AD8038/AD8039 FEATURES FUNCTIONAL BLOCK DIAGRAM Low power: 1 mA supply current/amp NC 1 AD8038 8 DISABLE High speed –IN 2 7 +VS 350 MHz, −3 dB bandwidth (G = +1) +IN 3 6 VOUT 425 V/μs slew rate –VS 4 5 NC
01 0
Low cost
51-
NC = NO CONNECT
29 0
Low noise
Figure 1. 8-lead SOIC (R)
8 nV/√Hz @ 100 kHz AD8038 600 fA/√Hz @ 100 kHz VOUT 1 5 +VS Low input bias current: 750 nA maximum –VS 2 Low distortion +IN 3 4 –IN
02
−90 dB SFDR @ 1 MHz
-0 51 29 0
−65 dB SFDR @ 5 MHz
Figure 2. 5-Lead SC70 (KS)
Wide supply range: 3 V to 12 V AD8039 Small packaging: 8-lead SOT-23, 5-lead SC70, and 8-lead SOIC VOUT1 1 8 +VS APPLICATIONS –IN1 2 7 VOUT2 Battery-powered instrumentation +IN1 3 6 –IN2 Filters –VS 4 5 +IN2 A/D drivers
03 0 1-
Level shifting NC = NO CONNECT
295 0
Buffering
Figure 3. 8-Lead SOIC (R) and 8-Lead SOT-23 (RJ)
Photo multipliers GENERAL DESCRIPTION
The AD8038 (single) and AD8039 (dual) amplifiers are high speed The AD8039 amplifier is available in a 8-lead SOT-23 package, (350 MHz) voltage feedback amplifiers with an exceptionally low and the single AD8038 is available in both an 8-lead SOIC and a quiescent current of 1.0 mA/amplifier typical (1.5 mA maximum). 5-lead SC70 package. These amplifiers are rated to work over The AD8038 single amplifier in the 8-lead SOIC package has a the industrial temperature range of −40°C to +85°C. disable feature. Despite being low power and low cost, the amplifier
24
provides excellent overall performance. Additionally, it offers a
21 G = +10
high slew rate of 425 V/μs and a low input offset voltage of 3 mV
18
maximum.
15 G = +5
The Analog Devices, Inc., proprietary XFCB process allows low
) 12
noise operation (8 nV/√Hz and 600 fA/√Hz) at extremely low
B d ( 9
quiescent currents. Given a wide supply voltage range (3 V to 12 V),
IN G = +2
wide bandwidth, and small packaging, the AD8038 and AD8039
GA 6
amplifiers are designed to work in a variety of applications
3
where power and space are at a premium.
G = +1 0
The AD8038 and AD8039 amplifiers have a wide input common-
–3
mode range of 1 V from either rail and swing to within 1 V of each
–6
04 rail on the output. These amplifiers are optimized for driving
0.1 1 10 100 1000
-0 51
FREQUENCY (MHz)
29 capacitive loads up to 15 pF. If driving larger capacitive loads, a small 0 Figure 4. Small Signal Frequency Response for Various Gains, series resistor is needed to avoid excessive peaking or overshoot. VOUT = 500 mV p-p, VS = ±5 V
Rev. G Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2002–2009 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION OUTPUT SHORT CIRCUIT ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS LAYOUT, GROUNDING, AND BYPASSING CONSIDERATIONS DISABLE POWER SUPPLY BYPASSING GROUNDING INPUT CAPACITANCE OUTPUT CAPACITANCE INPUT-TO-OUTPUT COUPLING APPLICATIONS INFORMATION LOW POWER ADC DRIVER LOW POWER ACTIVE VIDEO FILTER OUTLINE DIMENSIONS ORDERING GUIDE
