Datasheet AD8565, AD8566, AD8567 (Analog Devices) - 6
Description16 V Rail-to-Rail Operational Amplifier (Dual)
Pages / Page16 / 6 — AD8565/AD8566/AD8567. 100. VS = 16V. L = 10kΩ. VIN = 100mV p-p. CL = …
RevisionH
File Format / SizePDF / 294 Kb
AD8565/AD8566/AD8567. 100. VS = 16V. L = 10kΩ. VIN = 100mV p-p. CL = 40pF. TA = 25°C. AV = +1 T. A = 25°C. rees). T 60. Deg. –OS. ( T. 135. N (. 180
AD8565/AD8566/AD8567 100 VS = 16V L = 10kΩ VIN = 100mV p-p CL = 40pF TA = 25°C AV = +1 T A = 25°C rees) T 60 Deg –OS ( T 135 N ( 180
AD8565/AD8566/AD8567 100 VS = 16V VS = 16V 100 R 90 L = 10kΩ VIN = 100mV p-p CL = 40pF R 80 0 80 L = 10kΩ TA = 25°C AV = +1 T 60 45 70 A = 25°C ) rees) (% 40 90 T 60 B) Deg O –OS d ( T O 20 135 F 50 N ( SH AI HI G 180 S 0 40 E VER O +OS 225 HAS 30 P 270 20 10 0
014
10 100 1k
011
1k 10k 100k 1M 10M 100M LOAD CAPACITANCE (pF) FREQUENCY (Hz)
01909- 01909- Figure 11. Small Signal Overshoot vs. Load Capacitance Figure 14. Open-Loop Gain and Phase Shift vs. Frequency
18 1k TA = 25°C 16 14 100 p) V) p- 12 V E (m V G ( G S = 4.5V 10 A VS = 16V LT WIN 10 O 8 T S T V U U TP 6 TP VS = 16V OU A OU 1 4 V = +1 RL = 10kΩ DISTORTION < 1% 2 TA = 25°C 0 0.1 10 100 1k 10k 100k 1M 10M
012
0.001 0.01 0.1 1 10 100
015
FREQUENCY (Hz)
01909-
LOAD CURRENT (mA)
01909- Figure 12. Closed-Loop Output Swing vs. Frequency Figure 15. Output Voltage to Supply Rail vs. Load Current
4.5V ≤ V 150 S ≤ 16V I 60 R SINK = 5mA L = 10kΩ 135 CL = 40pF 50 T ) A = 25°C A 120 VCL = –100 V dB 40 ) S = 4.5V ( V 105 IN m ( 30 GA A GE 90 VCL = –10 20 OLTA 75 -LOOP D 10 E T V A U 60 VCL = +1 0 TP VS = 16V LOS C 45 OU 30 15 10 100 1k 10k 100k 1M 10M
013
0 –40 25 85
016
FREQUENCY (Hz)
01909-
TEMPERATURE (°C)
01909- Figure 13. Closed-Loop Gain vs. Frequency Figure 16. Output Voltage Swing to Rail vs. Temperature Rev. G | Page 6 of 16 Document Outline Features Applications General Description Pin Configurations Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Input Overvoltage Protection Output Phase Reversal Power Dissipation Thermal Pad—AD8567 Total Harmonic Distortion + Noise (THD + N) Short-Circuit Output Conditions LCD Panel Applications Outline Dimensions Ordering Guide
