Datasheet AD8565, AD8566, AD8567 (Analog Devices) - 7 Manufacturer Analog Devices Description 16 V Rail-to-Rail Operational Amplifier (Dual) Pages / Page 16 / 7 — AD8565/AD8566/AD8567. 150. 160. ISOURCE = 5mA. VS = 16V. 135. ) 140. TA = … Revision H File Format / Size PDF / 294 Kb Document Language English
AD8565/AD8566/AD8567. 150. 160. ISOURCE = 5mA. VS = 16V. 135. ) 140. TA = 25°C. S = 4.5V. 120. TIO (. A 100. m 105. N R. CT JE. +PSRR. OLTA. T V U. –PSRR
Text Version of Document AD8565/AD8566/AD8567 150 160 ISOURCE = 5mA VS = 16V 135 ) 140 TA = 25°C V dB S = 4.5V 120 120 ) TIO ( V A 100 m 105 ( N R GE 90 IO 80 CT JE 60 +PSRR OLTA 75 RE T V U 60 VS = 16V LY 40 –PSRR TP PP 45 20 OU SU 30 ER 0 W 15 PO –20 0 –40 –40 25 85 017100 1k 10k 100k 1M 10M 020TEMPERATURE (°C) FREQUENCY (Hz) 01909- 01909- Figure 17. Output Voltage Swing to Rail vs. Temperature Figure 20. Power Supply Rejection Ratio vs. Frequency500 V A S = 16V V = +1 450 R T L = 10kΩ A = 25°C AV = +1 400 TA = 25°C 350 IV) Ω) D ( 300 VS = 4.5V V/ E (3 250 G DANCE A E P 200 LT IM VO 150 100 50 VS = 16V 0210100 1k 10k 100k 1M 10M 018TIME (40µs/DIV) 01909-FREQUENCY (Hz) 01909- Figure 18. Closed-Loop Output Impedance vs. Frequency Figure 21. No Phase Reversal1.8k VS = 16V V 140 S = 16V TA = 25°C 1.6k TA = 25°C 120 1.4k 100 1.2k B) 80 lifiers) d 1.0k 60 Amp RR ( ( Y 800 CM 40 IT 20 600 UANT Q 0 400 200 0 10 100 1k 10k 100k 1M 10M 019–10 –8 –6 –4 –2 0 2 4 6 8 10 022FREQUENCY (Hz) 01909-INPUT OFFSET VOLTAGE (mV) 01909- Figure 19. Common-Mode Rejection Ratio (CMRR) vs. Frequency Figure 22. Input Offset Voltage Distribution Rev. G | Page 7 of 16 Document Outline Features Applications General Description Pin Configurations Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Input Overvoltage Protection Output Phase Reversal Power Dissipation Thermal Pad—AD8567 Total Harmonic Distortion + Noise (THD + N) Short-Circuit Output Conditions LCD Panel Applications Outline Dimensions Ordering Guide
