Datasheet AD8571, AD8572, AD8574 (Analog Devices) - 7
DescriptionZero-Drift, Single-Supply, Rail-to-Rail Input/Output Operational Amplifiers
Pages / Page28 / 7 — Data Sheet. AD8571/AD8572/AD8574. TYPICAL PERFORMANCE CHARACTERISTICS. …
RevisionF
File Format / SizePDF / 488 Kb
Data Sheet. AD8571/AD8572/AD8574. TYPICAL PERFORMANCE CHARACTERISTICS. 180. VS = 2.7V. VS = 5V. 160. CM = 1.35V. VCM = 2.5V. TA = 25°C. 140
Data Sheet AD8571/AD8572/AD8574 TYPICAL PERFORMANCE CHARACTERISTICS 180 VS = 2.7V VS = 5V 160 CM = 1.35V VCM = 2.5V TA = 25°C 140
Data Sheet AD8571/AD8572/AD8574 TYPICAL PERFORMANCE CHARACTERISTICS 180 180 VS = 2.7V VS = 5V 160 V 160 CM = 1.35V VCM = 2.5V TA = 25°C TA = 25°C 140 140 RS RS IE 120 IE 120 IF IF L L P P 100 100 AM AM F F 80 80 R O R O BE 60 BE 60 NUM NUM 40 40 20 20 0 0 –2.5 –1.5 –0.5 0.5 1.5 2.5
007
010
OFFSET VOLTAGE (µV) OFFSET VOLTAGE (µV)
01104- 01104- Figure 7. Input Offset Voltage Distribution Figure 10. Input Offset Voltage Distribution
50 12 VS = 5V 40 TA = –40°C, +25°C, +85°C VS = 5V 10 VCM = 2.5V TA = –40°C TO +125°C A) 30 p ( +85°C RS IE 8 NT 20 IF L P 10 AM CURRE 6 F AS +25°C R O BI 0 BE UT 4 –10 INP NUM –40°C 2 –20
008
–30 0 0 1 2 3 4 5
01104-
0 1 2 3 4 5 6
011
INPUT COMMON-MODE VOLTAGE (V) INPUT OFFSET DRIFT (nV/°C)
01104- Figure 8. Input Bias Current vs. Input Common-Mode Voltage Figure 11. Input Offset Voltage Drift Distribution
1500 10k VS = 5V V T S = 5V A = 125°C TA = 25°C 1000 1k A) ) p V 500 ( m ( NT GE 100 0 CURRE OLTA SOURCE AS –500 T V 10 U SINK BI TP UT –1000 OU INP 1 –1500 –2000 0.1 0 1 2 3 4 5
009
0.0001 0.001 0.01 0.1 1 10 100
012
COMMON-MODE VOLTAGE (V) LOAD CURRENT (mA)
01104- 01104- Figure 9. Input Bias Current vs. Common-Mode Voltage Figure 12. Output Voltage to Supply Rail vs. Load Current Rev. F | Page 7 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATIONS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 5 V ELECTRICAL CHARACTERISTICS 2.7 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS FUNCTIONAL DESCRIPTION AMPLIFIER ARCHITECTURE BASIC AUTO-ZERO AMPLIFIER THEORY AUTO-ZERO PHASE AMPLIFICATION PHASE HIGH GAIN, CMRR, AND PSRR MAXIMIZING PERFORMANCE THROUGH PROPER LAYOUT 1/f NOISE CHARACTERISTICS RANDOM AUTO-ZERO CORRECTION ELIMINATES INTERMODULATION DISTORTION BROADBAND AND EXTERNAL RESISTOR NOISE CONSIDERATIONS OUTPUT OVERDRIVE RECOVERY INPUT OVERVOLTAGE PROTECTION OUTPUT PHASE REVERSAL CAPACITIVE LOAD DRIVE POWER-UP BEHAVIOR APPLICATIONS INFORMATION 5 V PRECISION STRAIN GAGE CIRCUIT 3 V INSTRUMENTATION AMPLIFIER HIGH ACCURACY THERMOCOUPLE AMPLIFIER PRECISION CURRENT METER PRECISION VOLTAGE COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
